2006 tC acceleration, 2nd gear, and wearing shoes...help plz
Hi guys,
I got my tC back in early August, and it is a 06' manual trans. It was my first manual transmission, so it took awhile to learn. However, i think i know how to drive it ok at least. Anyways, it seems that auto trans cars around me can accelerate just as fast, or faster than me. I shift around 3000 rpms, could this be it? Do i have to go up to 4500-5000 rpms to accelerate faster? Am i doing something wrong?
Also, it seems to be hard to get from 3rd or 4th, back down into 2nd gear. Two times it has made a grinding sound, even though the clutch is all the way down. Is this stripping the gears, or just not in gear?
Finally, does anyone have trouble driving their manuals with shoes on? I have bigger feet (size 14), but i find that i must drive without my shoes on. The souls of my shoes catch the pedals to much and i cant shift well.
Thanks.
Dan
Thanks.
Dan
that grinding noise is call grinding gears try not to do that and dont down shift that far. also yes the higher the rpm the faster remember not 2 past 6krpm. the way i learn how to drive stick was each gear not 2 past more then 10-15mph without abuse. and if your at 4th gear down shift to 2nd depending on speed u will hurt ur trans
if i was right double clutch was really 4 some who clutch is going and you need to engage and disengage to have it 2 get into gear. and depends everyone knows that 1st 2nd and 3rd gears are really all the power is at and is stronger then 4th and 5th due to the size of the gear
Ok. You want to accelerate fast? REV your engine. Don't be afraid to. Someime when no one's around stomp it in second. Shift up at 5700 rpm's. Around there is the peak of the hp curve.
Secondly are you accidently letting yoru clutch out just before you're COMPLETELY in gear? Otherwise if you're doing everything right you should not have grindation. If you're missing shifts then maybe you should just let the car sit, while its off and practice moving the shifter.
Any other questions?
I don't know about size 14, but don't try it in 3" heels!! The heel gets stuck on the floor mat - not good. In my experience as a "girl driver" the high rpm's will get you a cleaner shift but less MPG. It's a trade off.
How fast are you off the clutch? Auto cars can match you if your footwork isnt quick enough. Im still learning a perfect clutch balance myself. thats probably more important than what rpm you shift at. As for your grinding gears, make sure that your stick is all the way in gear and the clutch is down.
-.- if u wanna beat them rev ur engine atleast 1.5 or something then take off hehe... you'll get use to it. I remember i had to drive my 5speed just by myself, i had to learn it in the hard way. if u want u can get a short shifter lol that should help you.
Usually for the shoe bit (i wear a 13) i just take off my right shoe, so that way it is free to press the gas and the brake. Your left foot you should only be using for the Clutch, so that shouldnt be getting in the way.
Originally Posted by TCMONKEE
isn't 2nd everything under 20 mph? Should also learn to rev match if you haven't or double clutching for smoother engagment.
Double clutching in a fully syncro'd transmissing like the tc's is a COMPLETE waste of time and Totally unneccessary! BEfore you give advice, please check the accuracy of your comments!
When you are downshifting. You want to do this very quickly
clutch to the floor
rev it up
shift down.
clutch out
Not shift down then rev.. you can grind or have trouble getting it in gear.
clutch to the floor
rev it up
shift down.
clutch out
Originally Posted by dano9258
Hi guys,
Thanks.
Dan
Thanks.
Dan
Did you even test drive the car before you bought one? Why buy someting that you cant drive comfortably....
Anyway you are going slower that auto cars because you are feets not quick enough. Your clutching is too slow. Don't pop the clutch but you should let it out as fast as you can. I have no problem beating auto cars and I shift aroun 3k rpm.
He's just new to cars and driving them.
Stomp on the gas, and the motor will start to pull. Shift at redline for maximum acceleration.
If you're cruising, easy on the gas and shift at 3k.
