mounting amps
Old Jan 24, 2006 | 05:20 AM
yellot00tr's Avatar
Default mounting amps
where is everyone mounting there amps? i had them mounted on the back of the seats before, but i didn't really like that location. mounting them underneath the trunk piece would be ideal, but i need to keep the spare tire. the other issue is that i'd like to keep some room in the trunk. at this point, i'm looking into building a rack that would go side to side in the trunk, right in back of the seat. it'd basically be a 2in piece of carpeted plywood(42" across, 15" high), and then mounted with L-brackets to the side and floor. i'd put 2 amps on it, and the capacitor in the middle. the only problems i'm having with doing it is that i guess i'd have to cut out 2 sections of it right near each amp in order to run wires thru, and also, with an enclosure like the quarterwave, the right side has to be an inch or 2 shorter to accomodate the enclosure. so far this and the quarterwave enclosure is the only setup i can think of that'd still allow me to keep some kind of space in the trunk, and looks good. anyone else have any other suggestions or did a diff setup?
Old Jan 24, 2006 | 07:40 AM
Dr_Isotope's Avatar
You just need to pick the right amp...
from above:
Old Jan 24, 2006 | 07:52 AM
xbbscion's Avatar
^^ whoa thats a nice install
Old Jan 24, 2006 | 07:31 PM
Phixeus's Avatar
i put mine under the driver seat. its a small Soundstream amp but it does the job right.
Old Jan 24, 2006 | 09:15 PM
yellot00tr's Avatar
i like that setup alot, but i'd be stuck with where to put the other amp. i'm gonna be using 2 infinity reference amps-the 7541 to power the front and rear components, and the 611a to power the subwoofer. mounting them on the rear seat worked fine, but looks like a rats ___. also, i'm getting the quarterwave enclosure to fit in that spot.
Old Jan 24, 2006 | 09:35 PM
Dr_Isotope's Avatar
Take off the rear speaker trims-- there's a cavern in there. You can fab up a bracket to mount one amp on each side, and not even have to get in the trunk. Lots of folks have put their amps in there.
Old Jan 26, 2006 | 02:35 AM
pillage's Avatar
mine is on the back of the seat I thought about putting it under like the pic above but decided not too.The V12 mono amp will be next to it soon
Old Jan 26, 2006 | 02:51 AM
yellot00tr's Avatar
that's where i had mine mounted before, but it's not enough room for 2 amps and a capacitor, which is why i'm trying to figure out what other ways to do it. i'm gonna just end up building a custom rack and put the amps and cap all on it.
Old Jan 26, 2006 | 03:15 AM
Hoeney's Avatar
this is the way i mounted my amp. plus this amp is freaking huge
Old Jan 26, 2006 | 03:39 AM
Harmonic_tC's Avatar
here is my setup, sounds like what you want to do
Old Jan 26, 2006 | 04:38 AM
vinh's Avatar
seems like that piece of foam was meant to hold an amp. i have my kicker kx550.3 there to. i had to shave down the foam piece a lil but its in there now
Old Jan 27, 2006 | 06:42 AM
RFR79's Avatar
looks good everyone I will be posting my setup this weekend
Hydryman
Feb 23, 2016 03:35 PM
crimson10tC
Sep 10, 2015 08:44 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
DJrepresent
Aug 12, 2015 06:37 PM
