I NEED SOME TECH HELP!!
first off i have an 05 xB and heres my problem...... i went to go turn on my heat 2 days ago and i noticed that nothin was happening. fisrt click... nothin, second click....nothin, third click.... nothin. i then turned it to high and it worked. so my problem is that my HVAC controls only work on high. anyone havin this problem or know what to do to fix it. any help would be greatly appriciated.
This happened to my old car. You see there is two different fuses: One controls all the lower settings, and one for high. Most likely your fuse for the first three settings is blown, so yeah let the warranty take care of it.
If it has not changed from the 2004 model, the schemetic shows a fuse inside the "blower resister" (Scions Name). This resistor is not used for high speed. High speed only goes through the 40A heater fuse, but any speed other than high has to go through a fuse built into the "Blower Resister" It looks like you have blown the blower resister. It would be a warrantee item, but if you are out of warrantee, PM me and I can tell you where this Blower Resister is located. This Electrical Wiring Diagram book for the xB is great. It just arrived today and it tells it all. I just have to spend some time learning their "lingo".
On the schematic, it looks like it would be easy to get to (the Blower Resister that is), but you would have to purchase it from Scion. It looks like it is behind the lower right most portion of the glovebox.
Music City Scions
The resister should be mounted in the heater case behind the glovebox with a few wires going to it. It's a common problem but not on such a new vehicle. If that is the problem I'd have it checked under warranty just so it doesn't happen again.
I'm looking for the schematics and wiring colors for the rear wiper motor and the rear deck lid stop/license plate lighting.
Originally Posted by jethro_b
The wiring schematic is in the factory service manual on the web site but you need to be a premium member to access it.
Do I need to alert the webmaster of the missing links?
Thats weird. I thought for sure there would be a total vehicle schematic. I searched for it with no luck.
Some manufacturers now seem to think the electircal manual needs to be separate..
Music City Scions
Does anyone know if there is an electric manual available for the xB. It would be a great addition to the shop manual for sure. I bet Tomas or Darren would know one way or the other.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
