Tapping into the cigarette lighter????
Old Jan 28, 2006 | 01:06 AM
Fsu1dolfan's Avatar
Default Tapping into the cigarette lighter????
okay here is the deal
i have an led thing that i would to install
it has a black and red wire
black = ground
red= power source
(correct me if i am wrong)
but here is my problem
the cigarette lighter has a black and white wire.
i am not sure which one i am suppose to tap into....also where is there a good grounding spot down in the shifter area.....i see four big bolts that hold the shifter in place but i am not sure that i should use that???'
any help???
Thanks in advance!!!!
Old Jan 28, 2006 | 01:28 AM
Fsu1dolfan's Avatar
anybody...
Old Jan 28, 2006 | 02:24 AM
pillage's Avatar
blk ground white power.....I would find another place or put an inline fuse just in case...
j3st3r's Avatar
Music City Scions
The white wire should be your power. Yes you could use one of the bolts from the shifter to ground your LED.
I guess a couple of questions/comments
1) What will the LED be used for? I am asking because running an LED into your cigarette lighter will turn the LED on everytime the vehicle is turned on, unless you have/are going to wire in a switch.
2) Does the LED already have a resistor wired in? Most LED's will require a resistor to be wired in to bring the voltage to the right level
Old Jan 28, 2006 | 02:27 AM
scottle's Avatar
NO NO NO i think the black is the power. i used my cigarette outlet to run my t v's. just look at it the wire that is connected to the middle of the outlet is power. the one that is connected to the side of cigarette lighter is ground
Old Jan 28, 2006 | 02:40 AM
j3st3r's Avatar
Music City Scions
Like I said the Black wire is the power....oops I guess a real easy way would be to put a meter across it just to be sure.
Hey scottle what headrests/monitors do you have? Where did you get them? How much? I just installed my ps2 and am trying to find the best headrest setup.
Old Jan 28, 2006 | 04:40 PM
Fsu1dolfan's Avatar
i got it guys....for future reference
The cigarette wires
Black = ground
White = Live power source
So if you need to connect something with red and black
red goes to white
black goes to black
its looks great and ill post pictures in a another thread later
Old Jan 29, 2006 | 04:22 AM
Mmartin_47's Avatar
In my car.. black is power, white w/ black stripe is ground. I used a 12v tester...
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
ScionLife Editor
Sep 15, 2015 04:40 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
JonathonK
Aug 26, 2015 08:30 PM
