Having a problem installing Ingalls ETD
Old Feb 3, 2006 | 02:07 PM
Simplyscion's Avatar
Team No Limitz
Default Having a problem installing Ingalls ETD
Ok, so I got all the brackets in and the strut tower bracket is sooo close to the AC line that when I go to connect the shock, it wont fit cause of the AC line and to boot, it wont line up with the motor mount bracket either. I dont know what the hell to do here...any suggestions?? Another thing is that when I installed the long bolt for the motor mount bracket, the gold washer didnt even sit properly. It seems like my bracket could have been slightly off and as I was tightening it down, it was bending the washer
Old Feb 3, 2006 | 06:34 PM
Schuller's Avatar
Have you tried getting all the nuts and bolts in loose then tightening them all?
There is a diy thread open now that could help with the rest.
Old Feb 3, 2006 | 06:40 PM
Team No Limitz
yea I tried doing that...I also have followed the DIY thread. It almost seems like the strut tower bracket doesnt extend as far as it should. It basically sits on top of the A/C line cap instead of sitting away from it like in every picture I have seen. This is frustrating
Old Feb 3, 2006 | 06:43 PM
zer0's Avatar
The gold washer goes on the other bolt not the long bolt... as per ingalls instructions... The Kaeon DIY on here is wrong.
http://www.ingallseng.com/Instructions/93027.pdf
Just did mine today, it was simple if you have all the right tools handy..
As for the shock not fitting, just extend it some, loosen it up till its the right length and it will slip on, then make it tight.
Old Feb 3, 2006 | 07:39 PM
Team No Limitz
ok...that will explain why the washer wouldnt fit
Even if I extend the shock, I still dont like how close it is to the AC line...it literally touches the bracket...I know that i didnt install that part wrong...it can only go one way. I am gonna take a picture on my sidekick and post it up cause I dont have a camera here at work...
Old Feb 3, 2006 | 08:41 PM
zer0's Avatar
loosen the 2 motor mount bolts and push the bracket towards the motor as close as you can, then loosen the ac cable bracket and push it as far over to the left as possible. Dynamat the AC line for extra assurance. you will be fine.
Old Feb 3, 2006 | 09:41 PM
Team No Limitz
I will try that I guess...check out the picture
Sorry for the crappy quality its from a sidekick
Old Feb 3, 2006 | 10:09 PM
zer0's Avatar
There is mine, I install'd the shock on top of the bracket so it would clear. If you need more closeups lemme know.
Old Feb 4, 2006 | 12:29 PM
Team No Limitz
Alright, I realized that being that I have the supercharger, they moved my AC line significantly so it would be out of the way...I gotta adjust the line and hopefully I will be all good.
Old Feb 4, 2006 | 12:44 PM
Petem's Avatar
il be curious to hear fromn you guys that are just installing this.... i know other have posted on how the car feels after the install.. but im trying to build a more accurate picture on how it really feels... i talking.. vibration... noise... performace difference.. any negatives or positives... not just ingals.. but MMW's aswell... thanks...
Old Feb 5, 2006 | 06:55 PM
Zadra's Avatar
I have mine installed.. I am trying to figure out how to keep it quite though I put dynamat between the bracket and strut tower and a piece between the bracket and my strut tower brace, but I can still hear every valve clicking in the motor, sounds like a have a hole in my fire wall....any ideas? I thought about using more dynamat. I find it to be a little loud..I'll let you know what happens, any pointers would help as well.....
Old Feb 5, 2006 | 09:19 PM
zer0's Avatar
I put some dynamat on the whole bottom of the strut tower bracket, covered it not just the shock tower, helpd a little. Make sure your o-rings are in the correct place as well.
Old Feb 6, 2006 | 12:30 AM
XD40tC's Avatar
Hey isnt that stiffy end supposed to mount UNDER the bracket? I thought thats how the instructions showed it. Unless it doesnt matter... just wondering.
Old Feb 6, 2006 | 02:41 AM
zer0's Avatar
Yea I fixed it and mounted it under the bracket, tried to find a way to quiet it down some... didnt work. Although the directions ingalls give you dont tell you where to place it on the strut bracket, they only mention the motor mount bracket...
randomsuper
20
Jun 13, 2015 10:56 AM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Alvie
Dec 12, 2014 05:04 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
