xB Drivers door lock sticking, Anyone else?
Old Feb 4, 2006 | 05:37 PM
LVXB's Avatar
Default xB Drivers door lock sticking, Anyone else?
Just started happening and I'm loathe to go to the dealer. anyone have a similar issue or associated fix?
The car still unlocks with the key its just when using the remote that it sticks in the locked position.
T.I.A.
Old Feb 4, 2006 | 05:56 PM
cherryBox's Avatar
yep, make that two.
started to notice it when the outside temp dropped below freezing, becasue I couldn;t get in may car. My lock would just not come up all the way. checked it out in a relatively warm day, and it just NEVER travels to the full upright position. I noticed that particular lock has quite a bit of rubbing going on - the shaft is scraped. none of the other door locks are doing this, so it's clearly catching on something.
This was at about 3000 miles.
no fix yet, but repeated presses of the unlock button will bring it to a point where I can open the door, when it's super cold, and won't go on the first try. I know...Iknow...
Old Feb 4, 2006 | 06:35 PM
LVXB's Avatar
all my locks have some degree of scuff and I can get it to work with multiple unlocks as well. but im in vegas and its only been near freezing a few weeks out of the last three months. oh and I'm pushing 43,000 miles.
Old Feb 5, 2006 | 01:07 AM
bB2NER's Avatar
Music City Scions
I'd check and see where it is dragging and tweak it so it moves freely. No problems with mine yet. Knock on wood.
Old Feb 5, 2006 | 01:30 AM
x_rayted711's Avatar
My aunt had this problem too after the temp dropped (cleveland). She thought the door was freezing shut. It was actually the lock not popping up all the way. I don't know whether she got it fixed or not.
Old Feb 5, 2006 | 01:50 AM
tat2dude25's Avatar
Yep, mine has almost 8K and all of my locks except the driver door does that. Temperature doesnt seem to affect mine. I just hit the Lock button a few times and unlock again it works. If not that the inside button always does the trick. I have read a post on this before, It seems to be very common on theese cars.
Old Feb 5, 2006 | 03:36 AM
cherryBox's Avatar
do you happen to remember what the post was? I can't seem to find it using the search...
Old Feb 5, 2006 | 06:38 AM
FREQBOX's Avatar
Same thing was happening to my drivers door lock when it was real cold outside.
When my installer was working on my doors he filed down the opening in the doorpanel, there are some bures or small pieces of plastic the lock rubs on. Looked like a simple fix and I havnt had any trouble since.
Hope that helps
Old Feb 5, 2006 | 07:22 AM
cherryBox's Avatar
hmm. door panel removal in 5...4...3...2...
Old Feb 5, 2006 | 07:46 AM
bB2NER's Avatar
Music City Scions
Hope that helps
That's basically what I said a few hours ago.
Old Feb 5, 2006 | 01:02 PM
xA_Factor's Avatar
I've not had this issue with mine. However, if I had/do I would remove the the door panel and shoot the linkage and the pull **** that pops out the top of the panel with a little silicone spray, I bet that would fix it. I wouldn't use WD-40 or any other oil-based lubricant. They tend to rot rubber and plastic.
Years ago, we had a similar problem with my wife's '92 MX-3. The above mentioned fix cured it. Although it was under warranty at the time, it was just quicker and easier for me to take care of the issue myself....just the way I am.
Old Feb 5, 2006 | 06:35 PM
LVXB's Avatar
the ****(altough scuffed on the sides) doesnt seem to be binding on anything. it seems more like a linkage issue elsewhere. Does anyone door of a panel removal walkthru somewhere on here?
Old Feb 5, 2006 | 07:01 PM
FREQBOX's Avatar
Hope that helps
Whats with the ?
You said exactly "I'd check and see where it is dragging and tweak it so it moves freely. No problems with mine yet. Knock on wood."
I told him exactly what was dragging on mine and what was done to fix it.
I stink cause i some how copied you?
Old Feb 5, 2006 | 08:54 PM
bB2NER's Avatar
Music City Scions
Didn't say you "stink". It just seemed like what I said was being ignored or didn't get read. That was what the doh was for. No offence meant Bro.
Old Feb 5, 2006 | 09:04 PM
cherryBox's Avatar
door panel removal-
1) remove screw in the door grab.
2) remove screw in door handle/latch assy (the thing you open the door with)
3) remove pop screw in the front edge of the door
4) start poppin stuff off.
there is a 48k pdf here:
http://www.superfa.com/TechSpecs/Loc...structions.pdf
Old Feb 5, 2006 | 10:48 PM
LVXB's Avatar
sweet! thx cherrybox
Old Feb 6, 2006 | 12:47 AM
FREQBOX's Avatar
sorry if i over reacted must be that time of month for me
Old Feb 19, 2006 | 07:22 PM
Tay831's Avatar
I have had this prob too took to dealer had for cuple days came back is better but still happens every great once in awhile.
WOOT Post #50
Old Feb 21, 2006 | 04:21 PM
ProshopXB's Avatar
Of the people that are having problems with the locks sticking, how many have had there doors off before. My drivers doorlock started sticking after i took the door to put my components in. Mine only sticks every blue moon or so and is not because of cold, cause its FL. But i do agree they are just binding on somthing.
Old Feb 21, 2006 | 04:24 PM
ProshopXB's Avatar
WOOT Post #50
They had your car for a couple of days to check the locks. Were they that busy or just plain slow. Cause it should not have taken a couple of days to check that. But if you didnt mind guess it really doesn't matter.
