cold cathodes question
Old Feb 6, 2006 | 03:30 AM
Sciond's Avatar
Default cold cathodes question
has anyone used the 15" ones inside the XB if so where did they fit???.....thinking of getting some from oznium.....any pics????????
TIA
Old Feb 6, 2006 | 05:02 AM
Spr0ket's Avatar
Haven't had a chance to play with the 15s yet. I'm sure they would work very well at the crook of the back seats though (measure 31" across to be sure). I'm getting ready to desheild a 4" cathode to put behind the A/C consoles.
Old Feb 6, 2006 | 01:28 PM
surfcitylocal's Avatar
Be super carefull with the cc tubes once you take them out of the tube, they can break if you just breathe on them wrong...trust me...I broke two over the weekend.
Old Feb 6, 2006 | 03:20 PM
Big_Jim's Avatar
i've taken about 6 of them apart so far for different projects, i found the best way so far was to heat gun the end of the platic and stretch it out. next, once you have about a half inch or so of slack, take a pair of diag cutters and cut the plastic, then you hit the end of the tbe with th eheat gun again, blowing the plastic out. you can slide the cathode out the open end after that. if you're like me, you'll need to pop the pins out of the plastic end for the transformer, so go ahead and do that to slide the wires through as well. Dont worry, when you put the wires back into the plastic clip, it does not matter what side you put each wire in.
For protecting the tube, i went to the local walmart and picked up some .25 inch air line hose for an aquarium. i cut off about 2 inches and heates that up to bend it straight (slid the tubing onto a thin screwdriver) and let it cool down. after the tubing straightens out, i slid the raw cathode into the tubing and glued the cathode in place.
hope this helps out a bit!
Old Feb 6, 2006 | 05:14 PM
What he said....I didn't heat up the tubing and that was what caused mine to break. Just the natural bend of the plastic (slight though it may be) was enough to break the cc's. You don't want to have that happen inside your ride. it's a mess.
Old Feb 7, 2006 | 02:06 AM
Sciond's Avatar
so then 15's in the back maybe the 12's in the front....???????
Old Feb 7, 2006 | 02:41 AM
Scott17's Avatar
StyleWagons
There's a much easier way to disassemble a cathode! Boil some water and dunk the end with the wire coming out in the water for 30 seconds and the hot-melt glue used to secure the tube will melt and the bulb will easily slide out. The tube is also left intact and the hole can be opened up to the tubes inside diameter and 2 bulbs can be slid into one tube if you want.
Old Feb 7, 2006 | 06:59 AM
CF_KC_WIDETC's Avatar
here is my cold cathode ligting from oznium I just install the this morning I have 12'' under dash and under seats,, and 4'' under my alpine , and here
Old Feb 7, 2006 | 05:05 PM
Jurisfiction's Avatar
Hey man,
I installed the 12" in all four footwells,
it's a bit hard finding a good spot to stick the passenger side, but once you find to flat surfaces, it's a piece of cake.
I'm sure the 15" tubes are cool and all, but the 12's put out more than enough light for me.
Ciao.
Old Feb 8, 2006 | 08:17 PM
Sciond's Avatar
thank you for the info people....Perrin_number_1 those pics were awesome! nice job!
Old Feb 8, 2006 | 08:26 PM
HeathenBrewing's Avatar
FYI - I have not seen it mentioned yet, so just to let everyone know, simply take out your glovebox when installing the 'thodes...makes it VERY easy.
Old Feb 9, 2006 | 01:16 AM
Sciond's Avatar
I was thinking about that good tip
Old Feb 9, 2006 | 01:24 AM
stick_1NZ's Avatar
I haven't tried the 15"s which I think it's too long. I've used 12"s and 4" which were easier to work with.
Here's where I used the 4".
Old Feb 9, 2006 | 01:36 AM
trainman0978's Avatar
now that is cool as h-e-double hockey sticks.
Old Feb 9, 2006 | 01:50 AM
Scott17's Avatar
StyleWagons
Third World strikes again!!! That roof lighting is sweet!
Old Feb 9, 2006 | 02:17 AM
stick_1NZ's Avatar
it's all the ideas you had put under my sleeve......
Old Feb 9, 2006 | 02:26 AM
Scott17's Avatar
StyleWagons
It looks like someones playing laser-tag in your car!
Old Feb 11, 2006 | 03:20 AM
Sciond's Avatar
that looks bada$$...your box always looks sharp
Old Feb 11, 2006 | 05:00 AM
I finally got my inverter to work and now I've got four 12 inch blues in my engine bay. I also have a _____in' home made ghetto switch....
And last but not least, my home made super duper ghetto switch.
Old Feb 11, 2006 | 09:28 PM
Sciond's Avatar
hey it works....and looks good...what else matter!
randode
44
Jun 29, 2004 04:19 PM
Opr8r
25
Jan 13, 2004 07:42 PM
randode
Nov 20, 2003 05:46 PM
Besk_one
Nov 17, 2003 09:28 PM
BlueBox
9
Sep 25, 2003 04:36 PM
