Rear Sway Bar pics
Old Feb 6, 2006 | 09:34 PM
318_tC's Avatar
Default Rear Sway Bar pics
Can someone please post pics of the rear sway bar. Also the bar that goes underneath the car? Thanks!
Old Feb 6, 2006 | 11:04 PM
gdirtayyy's Avatar
isn't that the same thing? o_O i don't know. ahhh i confuse myself of a strut from a sway now. o_O
Old Feb 7, 2006 | 12:03 AM
hahaitzskippy's Avatar
sway bar goes under the car.
and why do you need pics? product comparsion? trying to use a sway bar from a different car?
Old Feb 7, 2006 | 12:25 AM
318_tC's Avatar
I wanna see how visible it is
Old Feb 7, 2006 | 12:39 AM
tCb00b's Avatar
I dont know if this helps you or not but it is from an install so when it comes time for that it might be worth something. http://www.club-tc.com/forums/suspen...tallation.html
Old Feb 7, 2006 | 12:50 AM
Chemical_Whore's Avatar
i installed the Progress rear sway on Saturday. It's not visable at all. unless you're lying on the ground, then you can see the end links.
Old Feb 7, 2006 | 12:59 AM
here are some picks for you. . .
Progress left. Stock right.
Passanger side end link viewed from the rear of the car. (i was lying under the car to get this shot.)
Drivers side bracket w/ sway bar viewed from under the car looking toward the rear.
Old Feb 7, 2006 | 01:17 PM
MJVsTC's Avatar
Am I the only one who came to this thread thinking that 318_tC had pics of a sway bar?
Old Feb 7, 2006 | 11:01 PM
nodsetse's Avatar
Thanks! Didn't know the Progress bar came with different end links. I was going to get the TRD bar, but it uses the lame stock end links...now I'm unsure. Are the pick-up points in a different location too? Can't really tell from the pics.
Old Feb 8, 2006 | 04:11 PM
Pick-up points? do you mean, where the end links connect to? if so, then yes. it uses the same bolt holes.
i def recommend the Progress over the TRD. The Progress, so i hear, is much stiffer then the TRD. I have the Progress set to "race" and i def wouldn't want it to be any softer then it is.
Old Feb 8, 2006 | 08:56 PM
nodsetse's Avatar
Thanks and yes, that's exactly what "pick-up points" are. Had to ask because the location changed (for the better) with aftermarket bars on other cars I've had.
Old Feb 8, 2006 | 09:50 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
i had the TRD on until PROGRESS came out with theirs, u can feel the difference.
i would go with PROGRESS on this one, but TRD isn't that bad either
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
Squishface
Sep 15, 2015 06:51 AM
killahXB2
Mar 27, 2015 10:45 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
