225/35/17 Will they rub?
Old Feb 20, 2006 | 02:28 PM
MexBox's Avatar
Default 225/35/17 Will they rub?
Does anyone think these tires will rub if I'm running 17x8.5" wheels +25 offset
along with Tanabe df210's? Any help would be appreciated.
Old Feb 20, 2006 | 03:32 PM
ctruss's Avatar
Try mounting them up.
Old Feb 20, 2006 | 05:04 PM
MexBox's Avatar
I haven't bought the tires yet. Just wanted toknow because I don't want the stretched tire look.
Old Feb 20, 2006 | 06:39 PM
ctruss's Avatar
you can go as narrow as 215 on an 8.5" wide wheel and not have a stretch.
Old Feb 20, 2006 | 07:20 PM
MexBox's Avatar
So 215's wouldn't be a stretch then? I thought I saw a post with 215's on an 8.5"
wheel and looked like there was a stretch, I could be wrong though. thanks for the info.
Old Feb 20, 2006 | 07:30 PM
ctruss's Avatar
Wait, I'm wrong. 215's will have a slight stretch. 225 is your minimum width you can pick if you don't want stretch.
Old Feb 20, 2006 | 07:33 PM
MexBox's Avatar
225 it is then! Thanks again!
Old Mar 2, 2006 | 02:29 AM
MexBox's Avatar
I never got the answer I was looking for when I posted this before.
Old Mar 2, 2006 | 02:38 AM
RadRussXB's Avatar
I think they will scrub forsure, I mounted that size on mine from a buddies car because i wanted to run that size tire, and they rubed like hell the rims were 17x8 and I think a 35 offset I bet if you run 215 you will get a good stretch, or 205 45 will even be better but lot less rubber, I run 205 /40/17 on mine and the rubber is thin but I like the look and it rides pretty descent , but I watch out for potholes forsure to protect the rims , Im also lowered on Tein Tech S springs ,
Hope this helps, Russ
Old Mar 2, 2006 | 02:58 AM
MexBox's Avatar
I wasn't sure if they would rub or not but that helps knowing that u tried running a similar setup. thanks RadRussXB.
Old Mar 2, 2006 | 03:10 AM
chunk13's Avatar
when i do get rims on my car which will be a while cause the current tread is still pretty deep. i was looking at 17x7.5 w/ a 38mm offset wrapped in 215/40/17 and i have done some research. its really really close to stock diameter. i m just hopin i wont have problems w/ rubbing
amazing converstion tool:
http://www.1010tires.com/TireSizeCalculator.asp
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
jtucker7
Apr 8, 2015 05:41 AM
meowtc
Mar 5, 2015 02:28 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
