Fixing rubbing? Roll fender?
Old Feb 22, 2006 | 10:53 PM
Reese's Avatar
Default Fixing rubbing? Roll fender?
I did a search and came up with xA and xB and a broken link so im asking tC owners has anyone rolled a fender or fixed the rubbing issue somehow? On my rear left tire im rubbing a bit more and I can see where its rubbing, is there away for me to roll in the fender with out hurting my baby? Thanks for any info.
Old Feb 23, 2006 | 01:41 AM
HKSpeed's Avatar
nobody can guarantee against cracking paint. if the tire is barely rubbing, you can do a mild fender roll. the flatter you roll the fender lip, the greater chances of paint cracking. But, none of that is an issue because the hard-form trim around the rear fender lip will crack and fall off, exposing bare metal in the process. luckily you cannot see it from the outside, unless you crouch down and stick your face against the fender. I used touch up paint and clear coat to cover up the exposed metal.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
scionlife
371
Jun 2, 2015 11:00 PM
pdxgen2
Scion xB 2nd-Gen Wheel & Tire
Mar 14, 2015 01:56 AM
meechindisbeech
12
Feb 28, 2015 04:20 AM
2010tc805
Dec 12, 2014 06:47 PM
