feel of the short shifter
Old Feb 24, 2006 | 01:57 AM
peterkam's Avatar
Default feel of the short shifter
I recently installed the short shifter from creativecompacts. It feels really stiff when I change gears compared to my stock shifter. Is it normal or do I need to add more lubricant? If I add lubricant, will it shift smoother? This is my first time driving with short shifter. Any input will be helpful!
Old Feb 24, 2006 | 01:58 AM
Garage1217's Avatar
It will feel really stiff It is normal.
Old Feb 24, 2006 | 02:19 AM
peterkam's Avatar
what about if the short shifter is from other company such as trd or T&M?
Old Mar 2, 2006 | 05:39 PM
TWM_Performance's Avatar
Hi, depending on the tolerances used when machining the shifter, a shifter from one compagny may feel stiffer, if it's too tight in the housing. On the other hand, you don't want it to be too loose either, because it wouldn't be an upgrade. What you want is the perfect clearance between the main pivot point and the plastic housing.
We design, make and sell TC short shifters for over a year now and every shifter has thos tolerances.
http://www.twmperformance.com/shorts...rtshifters.htm
Thanks,
Jean-Sebastien
Old Mar 2, 2006 | 05:44 PM
peterkam's Avatar
Thanks for your information!
Old Mar 2, 2006 | 08:00 PM
yamaha16bw's Avatar
Got to love TWM! I got the stage 2 and its really smooth.
Old Mar 2, 2006 | 08:17 PM
SquallLHeart's Avatar
i wouldn't really say stiff.. but crisp... i love the solidity of the TWM stage two.. i got their bombshell **** with it too and it feels great...
also, i upgraded my bushings to something more solid... that also makes things feel even more crisp. and umm... doesn't hurt if you grease it up a little bit. i just took my finger and smeared some of the old stock grease onto the new one when i installed mine... it's not much.. but it works..
Old Mar 2, 2006 | 08:20 PM
DouBLeJ16's Avatar
Default Re: feel of the short shifter
Try a heavier shift ****, it'll feel alot better.
Old Mar 2, 2006 | 11:40 PM
VW2SCION's Avatar
yea it's alot stiffer but it's a good stiff ... haha anyways u gotta use it for a couple of weeks then it will feel good... when i first put it was crazy stiff and it didn't even want to go into the center of neutral on it's own... but once everything settles and all lubed it turns into the good stiff... enjoy
Old Mar 3, 2006 | 08:03 PM
EvilScion03's Avatar
I just recieved and installed the ARK Short Shifter and its good and stiff as well...but im thinking of putting a little bit more lube but man just driving around for bout 10 minutes and man do i love it...
carid
Nov 24, 2015 02:57 PM
NonStopTuning
Jun 29, 2015 07:42 PM
disaster06
Dec 26, 2014 03:00 PM
disaster06
Dec 4, 2014 07:05 PM
gularti
Dec 4, 2014 01:21 PM
