Seven Spokes
Old Feb 24, 2006 | 08:06 PM
05CAMO's Avatar
Default Seven Spokes
Opinions on the widest tire that would run on a 15x6 Alloy?
Would 205x55R15 work?
Old Feb 24, 2006 | 09:06 PM
ctruss's Avatar
205's are a little on the wide side but will work. 15x6" is the stock wheel size so why not just use your stock tires? If you need to buy tires I'd go up to a 195/55R15.
Old Feb 25, 2006 | 12:05 AM
05CAMO's Avatar
Thanks for your reply. I have the stock tires on now but would like to go wider . I'd think it would track better and the 185's just seem small.
Old Feb 25, 2006 | 02:07 PM
Subcompact Culture's Avatar
I thought the stock wheel size was 15x6.5?
Old Feb 25, 2006 | 02:30 PM
05CAMO's Avatar
These are the Seven Spoke wheels not the stock " steelies"
The size is stamped into the reverse side (15x6)
Old Feb 25, 2006 | 06:47 PM
RogerTTR's Avatar
FYI, you can run 215/50R15's as they will fit under the fenders without rubbing, and have a rim width range of 6.00 to 7.50 inches!
Old Feb 26, 2006 | 02:11 AM
05CAMO's Avatar
Thanks! I'm suprised to find that a 215 would run on a rim that narrow.
Old Feb 26, 2006 | 08:02 AM
SmokingTires's Avatar
I run 205/55/15 on a 15x7 rim, with a low offset, I'm also lowered on tanabe df210 and I didn't rub until I put OTG shims.
Old Feb 27, 2006 | 08:19 PM
05CAMO's Avatar
Any opinions on 225/50 /15 ? 40mm over stock tire width ?
Old Feb 27, 2006 | 08:21 PM
Im not sure I know with 205 I'm already rubbing the passenger side rear fender well. It doesn't do it now that I took the OTG spacers off but its damn close...
Old Feb 27, 2006 | 08:27 PM
05CAMO's Avatar
Thanks! Your drop from the Tanabe DF 210's is what about 2"?? The car looks great by the way!
Old Feb 27, 2006 | 08:29 PM
Yea I feel like it gets lower everyday, lol. Yea its approx. 2" but I cannot go into driveways without scraping the front lip, I can atleast go over speed bumps or I would take them off
Old Feb 27, 2006 | 08:34 PM
Oh yea, and Thanks!
Old Feb 27, 2006 | 08:44 PM
Stock Wheels/Tires
15"x5.5" +38 offset
Taken directly from the
FAQ
Old Feb 27, 2006 | 08:50 PM
05CAMO's Avatar
Thanks again but I'm working with the seven spoke alloy option wheels. 15x6 The ride is OK but the tire just looks too small for the car. Thought I'd try running a wider tire b/4 going the 18' + route.
Old Feb 27, 2006 | 09:00 PM
I am trying to sell my 17" they are just to heavy for the little added turning ability, I am going to keep my 15x7 for a while now... I like the look of the 205/50/15 it looks good only if it didnt rub...
Old Feb 27, 2006 | 09:49 PM
05CAMO's Avatar
New springs that might limit the drop to 1.5" out back might be cheaper. I've also seen others who made a few adjustments to the plastic wheel tubs on the rears.
It looks great though!
Old Feb 27, 2006 | 09:50 PM
Thanks! I am researching rear fender rolling as we speak...
Old Apr 15, 2006 | 05:17 PM
slickyricky102's Avatar
roll it with a baseball bat
Old Apr 15, 2006 | 08:09 PM
05CAMO's Avatar
That will add to the resale
StxArOne
Jul 13, 2015 06:25 PM
Audicted
Aug 3, 2004 03:08 AM
Back_In_Black_xA
Jul 10, 2004 03:21 AM
IAxB
Apr 2, 2004 02:21 AM
foxSCION
Jan 1, 2004 05:52 PM
