My New Capacitor
Old Mar 11, 2006 | 02:45 AM
xknowonex's Avatar
Default My New Capacitor
Check out my new toy!!! Its going to look really clean
Old Mar 11, 2006 | 11:55 AM
SCI_TC_GUY's Avatar
yeah.... that WOULD make a good paper weight.... hope your not trying to solve any dimming issues with that thing...
Old Mar 11, 2006 | 07:57 PM
illiniguy's Avatar
Caps are a waste of money. They actually cause more drain on your system in many cases
Old Mar 11, 2006 | 09:09 PM
kileil's Avatar
uh, no.
Here's some links explaining the benefits of capacitors in car audio.
http://ezinearticles.com/?Car-Audio-...-Them&id=74789
http://www.carsound.com/review_archi...pro_cap5.shtml
Old Mar 11, 2006 | 09:22 PM
bbcrud's Avatar
Scionetics
I guess it depends on how big (power hungry) your amp is.
I run a Memphis Baby Belle (600W Total) in my xB and don't need a cap. I have a friend running 2000 watts... he has caps on both amps.
Old Mar 13, 2006 | 12:59 PM
zm_br's Avatar
mmmm.tropicana
Old Mar 13, 2006 | 01:37 PM
BrEaK_AwaY's Avatar
um no.
caps will pull energy till the cap is full. once it is full it cant pull anymore energy there for it CANT drain your system.
rule of thumb
1 farad per 1000w
I am running two amps at 700w each, each amp has a 1.2 tsunami cap
I never head of that brand, so i hope it works for ya, but i would be very careful with buying caps, they can get VERY dangerious if installed wrong, tampered with wrong, and if its a cheap cap... i have seen them blow up, which is a BIG bang
just becareful is my best advice...
Old Mar 13, 2006 | 11:56 PM
illiniguy's Avatar
A cap basically acts as a bandaid that will give you a lil more reserve, but when that runs down it must recharge. I had 2 1 farad caps on my old setup rf 800@2 and they could not keep up. IMO most people are better off without them and just upgrading the big 3 and getting a good battery. Other than that a HO alt would be the next step.
Old Mar 14, 2006 | 06:53 AM
xknowonex's Avatar
http://www.almaniaudio.biz/products.html
Yea I dont even need it anymore. I upgraded the wires to the chassis and engine block. Made a huge improvement
Old Mar 14, 2006 | 11:30 AM
SCI_TC_GUY's Avatar
caps are fast charge/discharge.... they work well if they're used only to help stabilize voltage at low/normal listening levels... if you get dimming lights when you crank your subs, caps aren't going to help you... they could take care of a little noise induction, but you probably wouldn't hear the difference unless it's in your mid/high amp....
Old Mar 14, 2006 | 12:44 PM
dgHotLava's Avatar
sorry, anything that says 'HI END' is anything but...
Old Mar 14, 2006 | 12:50 PM
losmorob's Avatar
I prefer Homestyle with pulp.
Old Mar 14, 2006 | 01:02 PM
nikkisantoro's Avatar
What about caps? I cousin had a one thousand watt system on his corolla and ended up changing his alternator twice untill he installed a cap. I have one just to be on the safe side, because it s easier to intall install a cap at home then to run to the dealer, wait, and then wait some more and then pay a bill of 300.00 then to just buy one for 100.00 and youre good to go. I have a clarion dvd player of 224 watts, a one thousant watt amp and two ten polk 400 watts bass speaker, my system kicks nice and my cap looks nice in line with my system. So put it in and save youre self the headache.
Old Mar 14, 2006 | 01:07 PM
SCI_TC_GUY's Avatar
A burnt alternator is a FAR more serious problem than a capacitor can correct....that shows an inefficient amount of amperage being supplied from the alternator, causing it to TRY to give more, but it can't, so it burns.... capacitors won't add amperage, only a higher output alternator will... best bet is to keep the cap as a paper weight on your desk and upgrade the Big 3 with 2 or 0 ga. and get a better battery..
Kong
101
May 10, 2020 02:23 AM
trikkonceptz
Jun 7, 2015 01:46 AM
Neothin
Scion tC 1G ICE & Interior
12
Jan 4, 2007 11:45 PM
eggie
Oct 23, 2005 06:16 PM
riccochetrabbit
15
Jul 21, 2005 01:49 AM
