View Poll Results: Do ground wires make a difference?
yes
63.27%
no
36.73%
Voters: 49. You may not vote on this poll
ground wires.
Old Mar 20, 2006 | 06:47 PM
svt_to_xb's Avatar
Default ground wires.
ok, poll time those of us with ground wires. Poll Make a difference?
Old Mar 20, 2006 | 06:52 PM
SCI_TC_GUY's Avatar
more stable current flow... maybe a smoother idle but that's it... good for people with big stereo setups (ground wires = big3)
Old Mar 20, 2006 | 11:11 PM
ProshopXB's Avatar
Yup, i second SCI TC GUY, factory Toyota grounding is horrible, to be nice about it.
Old Mar 20, 2006 | 11:15 PM
dugzilla's Avatar
looks good, and I don't have a stutter in my idle any more.
Old Mar 22, 2006 | 03:41 AM
SwaTx21's Avatar
my idle sits at 300 - 500 rpm. sounds good. espiler exhaust, sounds like a dead v8. OHH yes
Old Mar 22, 2006 | 11:40 AM
SCI_TC_GUY's Avatar
^^ isn't that quite a bit low???? mt tC sits at 900 on the dot
Old Mar 22, 2006 | 11:57 AM
svt_to_xb's Avatar
I say you should check your wiring. It should idle at about 800 rpm when warm. You must have something wrong.
Old Mar 22, 2006 | 01:17 PM
brownKIDDnate's Avatar
i remember puttin the big three on my thunderbird (which i will be seelin today and pickin up the xa tomorrow) and even on a big v8 liek that grounding kits help.... a bit ^_^
Old Mar 22, 2006 | 10:14 PM
jct's Avatar
jct
mine idles around 700 rpm
Old Mar 23, 2006 | 12:25 AM
Big_Bird's Avatar
where could i pick up a set of ground wires?
Old Mar 23, 2006 | 01:25 AM
jct's Avatar
jct
you can make yer own
https://www.scionlife.com/forums/viewtopic.php?t=29261
Old Mar 25, 2006 | 01:12 PM
Sciond's Avatar
snake oil
Old Mar 25, 2006 | 03:21 PM
svt_to_xb's Avatar
Originally Posted by Sciond
snake oil
I will say, I have a background in electromechanics. in my understanding in electronics. The cleaner and less resistant path you can give voltage,the better. It's not snake oil, It's basic electrical theory.
chadfo's Avatar
snake oil
I have to agree. I put ground wires on mine because of the sound system. I didn't notice any other benefits from it.
Old Mar 27, 2006 | 02:27 AM
bB2NER's Avatar
Music City Scions
snake oil
Exactly right on. Makes idle smoother and helps overall efficiency of the electrical system. Snake oil That's funny
Mine idles in drive at 400-500 rpms. Butter smooth
Old Mar 28, 2006 | 12:27 PM
tdub57's Avatar
Default Ground wires?
Does installing an aftermarket grounding kit in anyway void the warranty? Does it have to installed by a certified mech? Is it better to make your own kit or buy one of the prefabs? Installation seems simple enough, just don't want any dealer service problems since it is brand new.
Old Mar 28, 2006 | 12:40 PM
svt_to_xb's Avatar
Default Re: Ground wires?
It will only void the warranty if the part is found to cause a problem. You can install it yourself. You can make your own to save money. Buying one just makes it easier.
Old Mar 28, 2006 | 12:48 PM
SCI_TC_GUY's Avatar
there's generally less unbolting and re-bolting for a kit made by you... the big 3 will give you same results with less small wires running all over...
Old Mar 28, 2006 | 03:14 PM
surfcitylocal's Avatar
I found out yesterday at the dealer that ground wires do indeed make a difference. I took my Box in for the 5000 miile oil change and to have them check out my A/C since it isn't working. The tech opened the hood, saw the grounding kit and prmoptly pronounced the A/C problem to not be covered by warranty. The service manager told me it would be 280 bucks to do a diagnostic of why the A/C isn't working. Oh, the other reason my warranty won't cover the A/C is because I commited a moral sin and installed an after market stereo. I'll be taking it to another dealer tomorrow.
Toyota: It's more than a feeling...of having a hot poker stuck up your backside!
Old Mar 28, 2006 | 03:20 PM
SCI_TC_GUY's Avatar
tell them that they have to do tests to PROVE the ground wires/aftermarket stereo was the cause of the problem... Magnuson vs. Moss act states that they can only void the warranty if the modification is the DIRECT CAUSE for the warranted part's failure... THEY MUST PROVE THIS!!!!
