HELP! Can't get rear drum covers off!!!! (SOLVED)
Old Mar 25, 2006 | 04:58 PM
Subcompact Culture's Avatar
Default HELP! Can't get rear drum covers off!!!! (SOLVED)
I'm trying to intall H&R rear spacers (longer studs) and I CAN NOT get the drum covers off.
I've taken the e-brake off, I've it it with with hammer, and i CAN'T get the dang things off!
Any suggestions?
Old Mar 25, 2006 | 05:17 PM
dmxsoulja3's Avatar
in my experience with drums a crow bar or pry bar and a big hammer were needed and I hit it from the front and banged it side to side and make sure there aren't any of those screws that need to come out with a hammer driver./
Old Mar 25, 2006 | 05:22 PM
Since my last post, I've been outside pounding the CRAP out of the driver's side rear drum (again, e-brake off) with a hammer and a wood blck. I attempted to begin to pry the drum cover with a screwdriver, but I don't want to bend the rear of the drum. Man, is this aggrivating!!!!!!
Old Mar 25, 2006 | 06:28 PM
dmxsoulja3's Avatar
theres an article about drum to disc swap maybe that will offer som advice?
Old Mar 25, 2006 | 06:38 PM
nytlemgr's Avatar
I do not own that car so I am not exactly sure but most cars I have worked on have 2 holes in the cover, their purpose is to screw 2 long bolts into the and turn each one so the cover will exactly push off!
Old Mar 25, 2006 | 06:57 PM
Yes -- correct. However, i"m not sure what size bolt I need to back the drums off.
Old Mar 25, 2006 | 07:38 PM
nytlemgr's Avatar
this may help...
https://www.scionlife.com/tech/manua.../xb04_1265.gif
Old Mar 25, 2006 | 08:13 PM
Thanks for the info. However, I'm still not sure I get it. Plus, I don't want to screw anything up with the drum.
This is so frustrating. I went and bought a big rubber mallet, and that didn't seem to do the trick. I went and bought 8mm x 1.25 screws to back the drum off with but they're the wong size!
Old Mar 25, 2006 | 08:22 PM
Okay, does anyone know what diameter/pitch screws you need to insert into the two holes in the drum cover to back the drums off? You can see where the holes are located in this picture:
Old Mar 25, 2006 | 08:30 PM
Jesboyhere's Avatar
the head of the bolt that is used is 10 mm
Old Mar 25, 2006 | 08:32 PM
I bought 8mm x 1.25 screws and they don't fit (just a hair too big). I need to know the diameter of the bolt itself and the correct pitch.
Old Mar 25, 2006 | 10:37 PM
Okay, so I managed to turn the self-adjusting wheel in the drum all the way. The drum STILL WILL NOT COME OFF! However, now the e-brake doesn't lock up that side of the car.
Old Mar 25, 2006 | 11:03 PM
Sorry for the tripple post -- I finally got one of them off! Now to just remove the studs.
Old Mar 26, 2006 | 05:22 AM
superjeer's Avatar
lol, so how'd you get it off?
Old Mar 26, 2006 | 02:43 PM
I used a bolt in one of the holes to back the drum off. I think it's a 12mm bolt; not sure of the pitch, though.
Old Mar 26, 2006 | 08:15 PM
Jesboyhere's Avatar
or instead of extending the studs to put wheel spacers on go to onetongarage.com and get the rear shim kit for the xb they run about 75 for a set and i do believe it is free shipping
Old Mar 26, 2006 | 09:00 PM
Those are 10mm. The H&R spacers I bought are 15mm.
airmankevin1
Feb 14, 2018 01:23 PM
carid
Jan 22, 2015 12:49 PM
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
Joeynenj
Nov 25, 2014 05:29 AM
