HELP!Installed OTG spacers and now wheels wont move. SOLVED
Old Mar 26, 2006 | 12:04 AM
1epoXyBox's Avatar
Default HELP!Installed OTG spacers and now wheels wont move. SOLVED
I know a lot of you peeps have installed these. Has anyone run into this? Help. Thanks!!!
Old Mar 26, 2006 | 12:12 AM
Max2k's Avatar
Are the wheels rubbing the fender?
Old Mar 26, 2006 | 12:20 AM
1epoXyBox's Avatar
No, there is no rubbing on the fender, nor any rubbing on the inside of the tire.
Old Mar 26, 2006 | 12:27 AM
kewlbox's Avatar
I hope you did not pinch the brake lines.
Or mayby see if the E-Brake is still on.
Old Mar 26, 2006 | 12:36 AM
1epoXyBox's Avatar
E-brake is down, I dont believe I pinched the brake lines. I took a lot of care not to pinch them.
Old Mar 26, 2006 | 12:50 AM
1epoXyBox's Avatar
Got it working!!!! Not sure why the the rear drums were stuck. Loosened the bolts holding the hub, and then re-tightened them. Now it rolls. Thanks for the help guys!
Old Mar 26, 2006 | 05:46 AM
1epoXyBox's Avatar
>>>----SOLVED----<<<
I used the bolts that shipped with the OTG spacer kit. The bolts were much longer than the original ones. What happened was that one of the bolts was interfering with the operation of the brake pad. The bolt was so long it was blocking the pad from moving. I solved the problem by using washers to "shorten" the bolt. The pad now has clearance to move properly. Hope this helps if anybody else has this problem.
Old Mar 26, 2006 | 11:53 AM
Sciond's Avatar
thanks for the info as that is a short term future mod
Old Mar 26, 2006 | 12:01 PM
smokeydog001's Avatar
Did you install 1 set of the 3/8" (9.53mm) thick shims or 2? Did you use the lock washers supplied with the kit?
Old Mar 27, 2006 | 03:12 AM
1epoXyBox's Avatar
I used one spacer shim per wheel hub, and used the supplied 3/8" bolt and lock washer. I have been riding on them for a day now with no further problems. I will probably have to check that the bolt with the washers on it stays tight. I unfortunately did not have a camera at the time of installation.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
terrye
Jan 25, 2015 05:31 AM
Beesh
Jan 9, 2015 06:30 PM
CAtC12
Dec 23, 2014 04:44 PM
scionara
38
Feb 25, 2004 04:52 AM
