xB Door Panel Removal????
Old Mar 27, 2006 | 05:28 AM
K-i-s-s's Avatar
Default xB Door Panel Removal????
ok i been searching for the last hour and cant seem any instructions on how to remove the door panels on a xb. i can find them for the xa and tc but no xb. can some one point me to the link please or let me know how to do it.
Old Mar 27, 2006 | 05:47 AM
Guamsilverbox671's Avatar
Are you removing all four door panels. I only know how to remove the front door panes. It's realy not that difficult.
There is a total of three screws that you will need to remove.
1st screw (wich is metal) is located at the door handle latch.
2nd screw (metal) is located at the door handle.
3rd screw which is plastic is located at the front section of the door panel (near the hidges)
once you remove the 3 screws, pry with a flat screw driver (covered in cloth) and genlty pry the panel from the botom and work you way to the top.
Disconect the harness that conects to the power window switch.
As far as the rear doors. I belive its relativley the same.
Old Mar 27, 2006 | 05:51 AM
K-i-s-s's Avatar
thank you so much, thats what i needed to know, THANK YOU!!!!!
Old Mar 27, 2006 | 12:51 PM
Sciond's Avatar
give a little push up also when removing it
Old Mar 28, 2006 | 11:52 AM
BTW are your removing the panels to change the speakers? Good luck becuase those thing are revited to the door structure
idriveanxa
Mar 8, 2015 12:03 PM
lunchbx05
Dec 29, 2014 07:53 PM
Joeynenj
Nov 25, 2014 05:29 AM
BlueBox
Mar 14, 2008 08:54 AM
swtbabiboi4u
Jan 4, 2004 04:03 PM
