DIY: Longer rear wheel studs
Old Mar 27, 2006 | 03:47 PM
Subcompact Culture's Avatar
Default DIY: Longer rear wheel studs
Although I don't have pics of the entire process, I figured I'd do a write-up of how to install longer rear studs. I learned a lot through this proceses, and hopefully it'll help others.
For this project, you'll need the following tools:
•Jack and jackstands
•Wheel blocks/chocks
•10mm, 12mm and 14mm sockets
•Two flatehead screwdrivers
•Rubber mallet
•Several 1/2" washers
•Metal bar
•Lug wrench
•Torque wrench
I bought H&R's 15mm wheel spacers, which require using logner wheel studs.
1) Loosen wheel lugs. Don't take them all the way off, just loosen them.
2) Make sure your front wheels have blocks/chocks under them, and that the car is in gear because you need to have the emergency brake off to remove the drums. Jack up the car, insert jack stands. I jacked my car up at the side jack points, and inserted stands right behind the jack points on the metal "pinch"
3) Remove wheel
4) Make sure your e-brake is OFF! Remove brake drum. Some have had luck hitting the drums with a hammer. I used a four-pound rubber mallet with no luck.
If this is the case, there are two small holes next to the stud openings. These are thredded and are for backing the drums off the hubs.
•Use a 12mm bolt (I'm not sure of the pitch; it may be 1.25), slowly turning the bolt until the drum comes off. If this doesn't work, there's a small access hole in the back of the drum that's plugged by a one-inch rubber stopper.
•Using a screwdriver, you can lift a small lever, then turn a wheel with some teeth on it (go counter clockwise) until the brake shoes ease up and you should be able to get the drum off.
5) This is what you'll see with the drum off
Using a hammer, I pounded out the studs from the hub. I used a regular metal hammer; my rubber mallet didn't work so well. A hard plastic hammer would probably work well, too.
6) When all the studs are removed, now it's time to put in the new studs.
You can see the H&R studs are 20mm longer than the stock studs, which requires you to take the hub off of the car.
As you can see, there isn't enough space to put in the longer studs without removing the hub.
7) Unbolting the hub is a multi-stop process. The hub area is the darker-colored circular part of the assembly (thanks to whoever took this photo)
•To unbolt the hub, first unclip the ABS sensor.
•Next, using a 10mm socket, remove the bolt holding the ABS sensor cord. Also remove the bolt holding the e-brake cable.
•Then, using a 14mm socket, remove the bolt holding the bracket, which holds barke line.
•On the back of the hub are four bolts. These are the four bolts that mate the hub to the back of the drum and/or dustplate. Unscrew these with a 12mm socket. You may need an extension to get at them. Be careful not the hit the metal brake line, though.
•Do NOT remove the brake line itself from the back of the drum unless you intend on bleeding the brakes. Instead, making sure the e-brake and ABS cables are unbolted/unhooked, wiggle the entire drum/hub assembly off of the rear beam, again, being careful not to bend or damage the brake line.
•While holding the entire assembly with one hand (remember, the brake line is still attached), carefully tap the back of the hub (round part with ABS sensor) out from the dustplate assembly. You can use a metal hammer, just be careful not to hit the ABS sensor. The entire hub assembly should pop out.
At this point, I put, make sure the brake assembly is not just hanging by the brake line. I simply looped the ABS cord around its respective bolt to secure it while I put the new studs in.
8: Insert the new studs. Don't worry about securing them. Just put them in the holes.
9) Reassemble the brake/hub unit, double checking to make sure everything is secure and properly tightend down.
10) Now it's time to seat the new studs.
I went to Home Depot and bought several 1/2" washers.
•With the hub on the car again (and fully secured) put several washers onto a loose stud.
•Next, put a stock lugnut onto a stud. Hand-tighten until the stud his held in place.
•With a lug wrench, or a deep socket, tighten the studs until they're seated. I positioned a metal bar inbetween the studs to keep the hub from spinning while seating the lugs. The seating process will require a lot of torquing and wrenching. Make sure the stud is 100% seated, though. Air tools would be nice here.
11) Reinstall the drum cover. If you had to loosen the rear drums, make sure you readjust the brakes so they function properly. To get the drum on, you may need to lightly tap them with a rubber mallet.
12) I now put my 15mm spacer on. Success!
Remember to torque everything down correctly, and you should be good to go!
Old May 25, 2006 | 05:24 PM
Sliphorn's Avatar
Nice Writeup. Thanks! I'll be doing this pretty soon.
Old May 25, 2006 | 05:32 PM
dgHotLava's Avatar
wil add this to tech section...
Old May 25, 2006 | 08:39 PM
Ed's Avatar
Ed
Did the studs come with the spacers or did you get them seperately? If seperate can you post the brand/part #?
Old May 25, 2006 | 08:51 PM
The studs came with the spacers.
Old May 26, 2006 | 02:01 AM
evilBOXevil's Avatar
Nice. Please, post some pics of the finished look. I want to see how it fills out the wheel well. Good write up.
Old May 26, 2006 | 02:10 AM
Thanks for the compliments. I wish I had some more pics of the work in progress.
Here are a couple of not-so-great pics; I'll get some more this weekend:
Old May 26, 2006 | 02:37 AM
Nice. It wouldn't seem like it would do so much, but it really does balance out the front rear gap. Looks great.
Old May 26, 2006 | 03:10 AM
Thanks. BTW: Chairman Kaga is great!
Old May 26, 2006 | 04:18 AM
TXboxdriver's Avatar
Default Re: DIY: Longer rear wheel studs
"Sushiboy"
i think i took this pic...whered ya get it
i remember doing a OTG rear spacer install write up long long ago
this pic was from that install
i just remember because everyone made fun of me for having my springs upside down
Old May 26, 2006 | 04:18 PM
tyrantcold's Avatar
I would swear i had those exact same wheels before , are they 15" sportmax ?
Old May 27, 2006 | 12:56 AM
TXboxdriver -- I found it on the net; I hope it is okay if I use it. If not, I'll take it down.
tyrantcold -- my wheels are 16" A-tech Finalspeeds.
Old May 27, 2006 | 01:45 AM
it's cool, no worries.
I just flipped those springs last weekend
and that pic ic from early last year....so lazy
Old Aug 31, 2006 | 03:41 AM
MikeC's Avatar
Thanks soooo much for the write up. You just saved me a couple of hours of "figuring time". Thanks again, and God bless! :D
Old Sep 4, 2006 | 04:20 AM
MikeC's Avatar
OK one difference that saved me some time was that after I knocked out the old studs, I just loosened and removed the foor rear bolts and pulled the hub out enough to place the new studs in and then tightened the rear bolts again. Next I "drew" in the new studs with an origional lugnut, and some washers. That saved me the time of undoing the abs sensor, and those two brackets. Thanks again.
Old Jun 13, 2009 | 03:54 AM
ToyoXrsPl's Avatar
anyone can bring this thread back to life ? pictures are gone and searching doesn't show any other thread that explains it with pics.
Old Jun 13, 2009 | 06:31 AM
Sorry; I don't have the pics anymore, either. Photos were hosted on a site that is no longer there. :-(
kleecker
9
Aug 2, 2022 05:00 AM
Miqmiqmiq
Jan 15, 2015 03:30 AM
tapetheducks
Scion xB 2nd-Gen Wheel & Tire
Jan 14, 2015 06:25 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
scionara
38
Feb 25, 2004 04:52 AM
