Regional - Pacific Mid CA, NV
auto shops in SJ to check alternator/battery
Old Mar 27, 2006 | 07:08 PM
IaMVinhamese's Avatar
Default auto shops in SJ to check alternator/battery
are there any in SJ that will do it for free? will toyota check them under warranty?
i took a volt meter to check my battery output and its only 13.8 when my engine is running.
i have a 550 watt amp but only using like 420 watts right now.
Old Mar 28, 2006 | 05:28 AM
05FMtC's Avatar
isnt that susposed to be ok, since a normal car battery is 12 volts??
Old Mar 28, 2006 | 08:16 AM
yeah a normal car battery is 12v but i thought when the alternator is on it should around 14.4
Old Mar 28, 2006 | 04:17 PM
maximus96's Avatar
any kragens or autozone will check them for free.
Old Mar 28, 2006 | 08:03 PM
Guest
Guest
Posts: n/a
Took the words right out of my mouth. They got the testers there at the shop.
Old Mar 28, 2006 | 08:19 PM
both kragen and autozone do not have info on the tC's alternator so they dont know how much voltage it should be at.
i called capitol toyota and asked the service people and they said around 14 and since mine was at like 13.8 they said it should be fine
would a capicator help with the light dimming? i am only pushing 420w right now so i dont know why they are dimming so much
Old Mar 29, 2006 | 06:28 AM
SquallLHeart's Avatar
grounding kit will help with light dimming... friends have them and swear it helps... even if so slightly.
Old Mar 30, 2006 | 06:33 PM
cf2's Avatar
cf2
have you pulled it out recently or anything like that...I guess I'm asking if you have loosened the belt at all on the alternator? If the thing isn't spinnin enough it'll cause problems.
Are you only experiencing problems when your stereo is on or, for instance, do your lights dim when sitting at a stop light with your blinker on?
Strader
25
Jul 22, 2004 09:27 PM
Inazuma
14
Jan 8, 2004 01:36 AM
Carson_Scion_TRD_Parts
Dec 30, 2003 09:29 AM
vho
Dec 9, 2003 11:44 PM
Docsnuff
9
Nov 23, 2003 09:50 PM
