engine noise problem with stereo need help!!!!
Old Mar 29, 2006 | 05:00 PM
K-i-s-s's Avatar
Default engine noise problem with stereo need help!!!!
ok last night i installed my 1200w amp and 1300w sub to the stock stereo. i think i have engine noise problem cause its really staticy. is there anyway to stop it, i even get static when i use my satillite radio. i had to use a rca converter and i hooked up the ground wire, but i still get noise any thoughts to help reduce this?
Old Mar 29, 2006 | 05:25 PM
ProshopXB's Avatar
Default Re: engine noise problem with stereo need help!!!!
So are you getting static or a whine? The amp is only for subs, correct? I have never heard an engine whine out of a sub amp. Where did you put the amp and where did you ground the amp at? What type of LOC (line out converter are you using)? In 5 years of installing i have never had to ground and LOC. Sorry for so many questions, but if you answer these i might be able to help you troubleshoot the problem. Let me know.
Old Mar 29, 2006 | 06:01 PM
mal75's Avatar
You need to find a better ground.
Old Mar 29, 2006 | 06:26 PM
cyclotron_burst's Avatar
^ Agreed. It sounds like a grounding problem if you are getting a whine when the engine is running. If the noise happens when the engine isnt running you probabally have another problem
Old Mar 29, 2006 | 09:17 PM
K-i-s-s's Avatar
its a static issue, and yes i only have the one amp hooked up to the one sub. im getting static in all of my speakers no just the sub. i spliced into the exstiting wires as to not cut them. as to the LOC im not quite sure ill have to check out the package, all i know is it had 5 wires that i was suppose to hook up, 2 for left, 2 for right, and one ground.
Old Mar 29, 2006 | 09:21 PM
ProshopXB's Avatar
Try unhooking the ground to the LOC and see what that does. Did you double check to make sure the wire's are correct left and right and there polarity? If it is causing static in all your other speakers to, then it most likely is you LOC in some way. Let us know.
Old Mar 29, 2006 | 09:30 PM
K-i-s-s's Avatar
i never thought about reversing the wires, you know what now that i think about it i think they are crossed, ill switch them as soon as i get home in about an hour, and let you know if that works and if it doesnt ill unhook the ground and see what happens also. thanks for the help by the way.
Old Mar 29, 2006 | 09:32 PM
ProshopXB's Avatar
Yes please let us know, and no prob thats what we are here for.
Old Mar 30, 2006 | 02:41 AM
K-i-s-s's Avatar
ok i think i fixed it, one the wires were crossed and 2 the ground wire on the rca converter wasnt hooked up. i revirsed them and it sounds a tone better. this is probably a stupied question but i hardly know anything about stereos so i want to know, why do people install sound deadner? what is it used for and what does it do? and thanks again for the help you did fix the problem.
Old Mar 30, 2006 | 02:51 AM
bassist1217's Avatar
they put it inside of door panels and under the carpet and such. cuts down on vibrations from the bass and eliminates rattles such as the infamous license plate rattle.
Old Mar 30, 2006 | 11:42 AM
Sciond's Avatar
one thing people aover look when installing amps..use a commen ground
Old Mar 30, 2006 | 07:24 PM
SCI_TC_GUY's Avatar
In the tech section, there's a post about having a noise free audio system that I think anyone with a stereo should read... if nothing else, just for a bit more of understanding...
Old Apr 8, 2006 | 11:25 PM
K-i-s-s's Avatar
do you happen to know the link for the noise free audio system?
Old Apr 9, 2006 | 02:36 AM
ProshopXB's Avatar
Here is the link for yeah, it's housed in the Tech. section.
https://www.scionlife.com/forums/viewtopic.php?t=104153
herwig
Scion tC 1G ICE & Interior
Mar 23, 2015 04:19 AM
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
cid_mcdp
Jan 5, 2015 02:45 PM
gularti
Dec 4, 2014 01:21 PM
