people w/ HID's in oem headlight...
Old Mar 30, 2006 | 06:20 AM
bww1980's Avatar
Default people w/ HID's in oem headlight...
do you lose the high beams? and do the lights turn off whenever you flash the high beams?
are the bi-xenons worth it? do they work pretty good?
thanks,
benjamin
Old Mar 30, 2006 | 06:32 AM
aireck's Avatar
i have the Bi-Xenons and i rarely use the highs...
these do come with a shield though so the cutoff is sweet and almost no glare.. haven't gotten flashed yet...
Old Mar 30, 2006 | 06:49 AM
bww1980's Avatar
can i ask where and how much???
i was reading about the luminic bulbs, how people are raving about they're the best thing next to the HID's?
i don't know, i might give the bulbs a shot. but i really like HID's. i had HID kits on my previous cars, but they were all double headlights (high beam is seperate from low beams). so i didn't have to worry about losing the high beams.
i really don't like the halo's or any other double headlights other than the jdm one's, but they are too expensive plus i'm not sure if the beam pattern are adjustable.
thanks,
benjamin
Old Mar 30, 2006 | 04:29 PM
Short_Bus's Avatar
my bi-xenons were $350 I beleive....so long ago when I got them....
Old Mar 30, 2006 | 05:38 PM
Scibox's Avatar
I have no high beams and i don't gey flashed.
Old Mar 30, 2006 | 06:09 PM
bww1980's Avatar
how long have you had it for?
can you tell me the place you got them from?
how was the install? plug and play like others?
thanks,
benjamin
Old Mar 30, 2006 | 08:49 PM
bww1980's Avatar
does your HID's turn off when you put it on high beams?
thanks,
benjamin
Old Mar 30, 2006 | 09:13 PM
elegancexb's Avatar
your regulars will turn off....with HId's you dont the highs pretty much
Old Mar 30, 2006 | 09:19 PM
hayalex6's Avatar
I've never even used my high beams.
Old Mar 30, 2006 | 09:20 PM
elegancexb's Avatar
hayalex6 did you had any problems intalling them.... did you high beam (blue) came on your dash....???
mine did ....
Old Mar 30, 2006 | 09:26 PM
bww1980's Avatar
thanks guys, after some research, i've found out there's one more type of HID, make it total of three options:
-H4 single beam, which many of you have, you lose the high beam
-H4 hi/lo, which low beam is HID, and high beam is halogen.
-H4 bi-xenon, which both high and low beams are HID.
i still haven't made up my mind yet, but i definitely don't want halos on my xb.
thanks,
benjamin
Old Mar 30, 2006 | 10:25 PM
hayalex6's Avatar
mine did ....
Sry I don't have HID's. When I do get them I sure won't get a P&P kit for my stock housing though.
Old Mar 31, 2006 | 12:46 AM
Short_Bus's Avatar
I got mine discounted from proxenon. I install very easy, had them for 1 year and a month to be exact....
Old Mar 31, 2006 | 03:00 AM
bassist1217's Avatar
i wouldn't want both high and low beams to be HID. my HIDs take a good 10 seconds or so to fully flicker on. i'd be fine with HID low beams and luminics or silverstar high beams.
Old Mar 31, 2006 | 03:04 AM
Scibox's Avatar
thanks,
benjamin
Yep. They turn off when you switch them on.
Old Mar 31, 2006 | 03:57 AM
thanks,
benjamin
yeah, i found that out the hard way...i was driving along and wondered, "hey, i wonder what happens if i switch to high beams..." *click* and it's pitch black.
Old Mar 31, 2006 | 03:59 AM
bww1980's Avatar
thanks guys, i appreciate your help.
benjamin
Old Mar 31, 2006 | 10:20 AM
now, if you need a set, i can hook you up. PM me if you're interested.
Old Mar 31, 2006 | 03:19 PM
Gaps720's Avatar
i have the luminics jdm yellow bulbs... i've been flashed 3 times on the same two-way road .
Old Mar 31, 2006 | 05:55 PM
bww1980's Avatar
you know our headlights are adjustable right?
my driverside beam was way off from the dealer, so i adjusted it, now it's all good.
benjamin
