Stock H/U with system
Old Mar 30, 2006 | 12:20 PM
PnZrFsT's Avatar
Default Stock H/U with system
Alright, alright. Don't tell me...I used the search button and couldn't come up with anything
Heres my question. I've got a whole aftermarket system to go in my Tc when I pick it up, but I'm not sure if I have any way of hooking up the RCA's to the factory H/U. Is there any way to do this? I figured there may be a chance since the bazooka is an option and it must be amplified. Thanks to whoever can help me out
Old Mar 30, 2006 | 12:34 PM
Tha_Dude_79's Avatar
I'm not sure.
but maybe this will help you out.
http://mobile.jlaudio.com/products_c...php?page_id=94
Old Mar 30, 2006 | 01:35 PM
PnZrFsT's Avatar
Looks like thats exactly what I would need if there is no RCA support. Thank you Dude
Old Mar 30, 2006 | 02:21 PM
SCI_TC_GUY's Avatar
The JL Cleansweep units are the best for integrating to an OEM HU.... but they're expensive!!
you could just use a Line Level Converter from anyone around but it's not going to give you quite the sound that the cleansweep or an AudioControl unit would give you..
Old Mar 30, 2006 | 04:20 PM
PghtC's Avatar
that Cleansweep unit looks awesome. It is pretty pricey...just wish I could hear the difference with one to determine whether it is worth it to buy that instead of an aftermarket radio.
Old Mar 30, 2006 | 04:35 PM
SCI_TC_GUY's Avatar
^^ i'd take the aftermarket HU anyady.... but the Cleansweeps are very good products
Old Mar 30, 2006 | 05:40 PM
titolito's Avatar
I hooked up a sub to my stock head unit. Here is what I used...
http://cgi.ebay.com/ebaymotors/SCION...51638034QQrdZ1
Old Mar 30, 2006 | 05:57 PM
zer0's Avatar
I have some line out converters for sale in PPC. I need to get rid of em. $10 shipped and you can have one.
https://www.scionlife.com/forums/viewtopic.php?t=106522
Old Mar 30, 2006 | 07:06 PM
chipmOnk's Avatar
I got quoted $300 for the Cleansweep about 3 weeks ago at my local stereo shop.
Old Mar 30, 2006 | 07:18 PM
socal_showdown's Avatar
I also used the RCA adapter from the ebay link a few posts up. It does the job and is easy to install. Highly recommended if you want a simple way to add some bass
Old Mar 30, 2006 | 07:20 PM
SCI_TC_GUY's Avatar
^^^ yea.... honestly, I'd only use the cleansweep if I was wanting to do some SQ competitions.... other than that, the standard RCA LOC will do the trick..
Old Mar 30, 2006 | 07:40 PM
tweetertc's Avatar
the cleensweep is cool...
just expensive... and i have only used it when the vehicles fact h/u is impossible to replace... or justoo expensive to replace... like i just used one in a G35... was giving me problems... but now the car sounds FANTASTIC...
for the money of a cleansweep.. you could get a phat deck and replace the stock one...
Old Mar 30, 2006 | 07:49 PM
SCI_TC_GUY's Avatar
^^ amen there....
Old Mar 30, 2006 | 09:31 PM
PnZrFsT's Avatar
Thanks for all the advice guys. I'll probably pick up one of those ebay ones to last me the time that I'm going to spend working on my carputer
Old Mar 31, 2006 | 03:00 AM
natodog's Avatar
Default hu
yeah id go with the thing on ebay, plug and play, plus the aftermarket sub is amplified but its in the box and the sound is not carried through rca wires like a normal sub, its through a pin connector from the HU to the sub, and the power is also carried in that
Old Mar 31, 2006 | 12:12 PM
PghtC's Avatar
yeah, I'm using the eBay thing too. Works well. I don't want to replace the factory radio...
Does anyone know if the factory radio will lock if you remove it? I know GM vehicles lock if they are unplugged and won't work until the dealer unlocks them. That's what i am afraid of...I want to be able to re-install it if I do replace it.
Old Mar 31, 2006 | 08:30 PM
titolito's Avatar
If this were the case, i would have been screwed many times over. I've removed the stock stereo so many times without a problem.
Old Mar 31, 2006 | 09:56 PM
PghtC's Avatar
good to know.
Old Apr 1, 2006 | 03:20 PM
PnZrFsT's Avatar
Hmmmm... this adaptor seems easy to make. Is there any chance anyone could lcheck which pins (and wire color) the RCA connector comes off of when looking at the back of the radio? It's worth 5 bux if someone can get the info to me today
Old Apr 1, 2006 | 05:08 PM
titolito's Avatar
I like the eBay adapter because it's a clean and easy install. No splicing and can be done in 5 minutes. But the cheapest way to do this would be to get a line level converter (about $10+)from some local audio shop or Best Buy or something. The instructions on how to hook it up are always included. You tap into/splice/whatever the left and right speaker lines for either your front or your rear speakers (or both depending on your set up).
The specific wire colors are:
LF - White
RF - Grey
LR- Green
RR - Purple
The striped wire is the (+) and the solid color is (-)
Remember that if you ever play with the fader and reduce the signal to whatever speakers you are tapped into, you will also lose the signal to your sub. But if you have an amp that can accept two sets of RCAs (i.e. Infinity Basslink), just tap both front AND rear speakers and you'll never have to worry about what your fader setting is at.
