Stock H/U with system
Alright, alright. Don't tell me...I used the search button and couldn't come up with anything
Heres my question. I've got a whole aftermarket system to go in my Tc when I pick it up, but I'm not sure if I have any way of hooking up the RCA's to the factory H/U. Is there any way to do this? I figured there may be a chance since the bazooka is an option and it must be amplified. Thanks to whoever can help me out
I'm not sure.
but maybe this will help you out.
http://mobile.jlaudio.com/products_c...php?page_id=94
The JL Cleansweep units are the best for integrating to an OEM HU.... but they're expensive!!
you could just use a Line Level Converter from anyone around but it's not going to give you quite the sound that the cleansweep or an AudioControl unit would give you..
I hooked up a sub to my stock head unit. Here is what I used...
http://cgi.ebay.com/ebaymotors/SCION...51638034QQrdZ1
I have some line out converters for sale in PPC. I need to get rid of em. $10 shipped and you can have one.
https://www.scionlife.com/forums/viewtopic.php?t=106522
the cleensweep is cool...
just expensive... and i have only used it when the vehicles fact h/u is impossible to replace... or justoo expensive to replace... like i just used one in a G35... was giving me problems... but now the car sounds FANTASTIC...
for the money of a cleansweep.. you could get a phat deck and replace the stock one...
yeah id go with the thing on ebay, plug and play, plus the aftermarket sub is amplified but its in the box and the sound is not carried through rca wires like a normal sub, its through a pin connector from the HU to the sub, and the power is also carried in that
yeah, I'm using the eBay thing too. Works well. I don't want to replace the factory radio...
Does anyone know if the factory radio will lock if you remove it? I know GM vehicles lock if they are unplugged and won't work until the dealer unlocks them. That's what i am afraid of...I want to be able to re-install it if I do replace it.
Hmmmm... this adaptor seems easy to make. Is there any chance anyone could lcheck which pins (and wire color) the RCA connector comes off of when looking at the back of the radio? It's worth 5 bux if someone can get the info to me today
The specific wire colors are:
LF - White
RF - Grey
LR- Green
RR - Purple
The striped wire is the (+) and the solid color is (-)
Remember that if you ever play with the fader and reduce the signal to whatever speakers you are tapped into, you will also lose the signal to your sub. But if you have an amp that can accept two sets of RCAs (i.e. Infinity Basslink), just tap both front AND rear speakers and you'll never have to worry about what your fader setting is at.
