View Full Version : Do i need modification with these sizes & offsets????
ckk81
05-26-2004, 05:25 AM
i was checking out some JDM wheels and found the sizes and offsets.....
RIM SIZE(OFFSET): 15X6.5(+9) 15X7.5 (+21)
BOLT PATTERN: 4X114.3
i know nothing about wheels and looking for help from experts(people on this forums)....
if it does fit...........what kind of spacers do i need to make it flush with the car?
thanks,
Jack
tinybigrig
05-26-2004, 06:37 AM
ok, so heres the deal, first off you will need a bolt pattern of 4x100, not 4 on 4 and a half, secondly those will stick waaaay out of the wheel well. in my opinion +35 up front and + 25 is the rear will give you the best look, but mostly it is your car pick the look you like, i wouldnt get anything above a +40 or +42 without needing to run spacers
brent
westsype
05-26-2004, 06:43 AM
How about pics of the wheel.
XBOXED
05-28-2004, 04:49 AM
How would 17x7.5 40mm up front and 17x7.5 20 mm rear look
jomo
05-28-2004, 05:48 AM
If you don't want to do much rolling or grinding of the rear fender, I would stick with tinybigrig's recommendations. I have a 35mm offset in front and a 20 mm offset in the rear. This is pretty much the same wheel track in front and rear. It looks good, but it was kind of a pain to work the rear fender such that it would not rub. Even with a 25mm offset in the rear, you may still rub. I know I would have.
