Problems with sunroof closing (tC)
Old Apr 4, 2006 | 08:32 PM
DouBLeJ16's Avatar
Default Problems with sunroof closing (tC)
This just started 2 days ago.. My sunroof will open without a problem then when I try to close it, it will close 80% of the way then all of a sudden it stops and goes in the other direction.
I checked the track and there wasn't anything blocking it.. It happened yesterday then just went away all by itself, now the problem is back.
Any easy fix for this or should I just take it to the dealer?
Old Apr 4, 2006 | 08:34 PM
THansenite's Avatar
Do a search. This has happened to many different people and I have seen many different posts on it. You need to reset your computer, then re-calibrate your sunroof.
Old Apr 4, 2006 | 08:38 PM
SCI_TC_GUY's Avatar
take it to the dealership....
Old Apr 4, 2006 | 08:44 PM
DouBLeJ16's Avatar
Alright, thanks! I'll be doing that in a few minutes.
Old Apr 4, 2006 | 08:45 PM
DouBLeJ16's Avatar
I will if the ECU reset doesn't work. The dealership around here is always really busy, I don't feel like waiting 2 hours for them to do what I could do in 10 minutes.
Old Apr 5, 2006 | 06:50 AM
Mexicola420's Avatar
i had this problem and i think its because the windows have a safety mechanism to where if there is any backpressure on the window, it will go the other way so as not to crush someones hand etc. all i did was wd-40 everything i could find in the track that would cause the slightest bit of friction and i havent had the problem since.... that was back in december......
Old Apr 5, 2006 | 11:20 AM
SCI_TC_GUY's Avatar
^^^ that sounds like a good idea..... what would work even better would be white lithium grease.... comes in a spray can.. good ____..
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
Nicole412
Mar 23, 2015 06:26 PM
idriveanxa
Mar 8, 2015 12:03 PM
the4kbeast
Feb 1, 2006 05:03 AM
