help with clear corner mod....
Old May 27, 2004 | 10:11 PM
ONE_HOT_BOX's Avatar
Default help with clear corner mod....
i took my headlights off the car to try the "hammer and a screwdriver method of removing the yellow reflectors in the front headlights. i got all but the little part on the very outside where it clips into the housing, how do u get that part out?
Old May 28, 2004 | 01:13 AM
windowtint's Avatar
you're gonna have to open the housing up - which I think is the route that should be done anyway - you're gonna have to no matter what if you want ALL the orange plastic out... may as well do it when the covers off instead of all the extra work of breaking it up.
Old May 28, 2004 | 02:37 AM
Minsk99's Avatar
I did the hammer method and got all the orange out. You will need to use a long thin pair of wire cutters and a long pair of needle nose pliers helps too. Also, I cut up a few shop towels and stuffed them in the hole so that I wouldn't scratch the plastic inside. You may have to push the plastic pieces that hold the orange in place back wards so that it falls behind the housing and then carefully shake the headlight around to get it to where it can be grabbed.
Old May 28, 2004 | 05:06 PM
CBSIMONSEZ's Avatar
Those little orange plastic tabs shoud fall out. If not, then get in there with a long thin screw driver and carfully nudge them loose. I would not suggest opening the headlight, cause chances are you will never get them to go back together again with a water tight seal. I would say be paitent, and just keep at it, they will fall out eventually.
Old May 28, 2004 | 10:58 PM
jynx's Avatar
is there another "how to" thread on how to do this mod?
Old May 28, 2004 | 11:38 PM
thanks, i had to use the car, so i put it back tofether, now i need to take it apart when i hava a day, and get it finished.
Old May 29, 2004 | 11:42 AM
CBSIMONSEZ's Avatar
If you do a search ( which may take awhile ) you will run across a link that someone has pics of the entire thing. Just take a minute or 2 and look deeper into it via the search function, its there.
The post i speak of was originally posted in either Feb. or March of this year i believe.
Old May 29, 2004 | 11:56 AM
CBSIMONSEZ's Avatar
I found it for you. Great job on the pics listed. Enjoy!
HEY MODS. COULD YOU MAKE THIS PART OF THE TECH INSTALL/DO IT YOURSELF ON SCION LIFE? I cant tell you how many times i have looked this thread up just for the information listed, along with the great pics.
https://www.scionlife.com/forums/vie...=clear+corners
BlingSlade
Oct 19, 2016 12:39 AM
prescottn
Oct 8, 2015 05:31 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
prescottn
Sep 13, 2015 09:04 PM
