help with clear corner mod....
i took my headlights off the car to try the "hammer and a screwdriver method of removing the yellow reflectors in the front headlights. i got all but the little part on the very outside where it clips into the housing, how do u get that part out?
you're gonna have to open the housing up - which I think is the route that should be done anyway - you're gonna have to no matter what if you want ALL the orange plastic out... may as well do it when the covers off instead of all the extra work of breaking it up.
I did the hammer method and got all the orange out. You will need to use a long thin pair of wire cutters and a long pair of needle nose pliers helps too. Also, I cut up a few shop towels and stuffed them in the hole so that I wouldn't scratch the plastic inside. You may have to push the plastic pieces that hold the orange in place back wards so that it falls behind the housing and then carefully shake the headlight around to get it to where it can be grabbed.
Those little orange plastic tabs shoud fall out. If not, then get in there with a long thin screw driver and carfully nudge them loose. I would not suggest opening the headlight, cause chances are you will never get them to go back together again with a water tight seal. I would say be paitent, and just keep at it, they will fall out eventually.
Originally Posted by jynx
is there another "how to" thread on how to do this mod?
The post i speak of was originally posted in either Feb. or March of this year i believe.
I found it for you. Great job on the pics listed. Enjoy!
HEY MODS. COULD YOU MAKE THIS PART OF THE TECH INSTALL/DO IT YOURSELF ON SCION LIFE? I cant tell you how many times i have looked this thread up just for the information listed, along with the great pics.
https://www.scionlife.com/forums/vie...=clear+corners
BlingSlade
Oct 19, 2016 12:39 AM
