Buyers Guide: Scion xA/xB Exhaust
Old Apr 15, 2006 | 06:38 PM
scionlife's Avatar
Founder
Default Buyers Guide: Scion xA/xB Exhaust
TRD Exhaust System
Type: Axle-Back
Part Number: 00602-17400-150
Colors: Polished
Application: Scion xB
CARB EO Status: Approved 2004-2006 xB
MSRP: $299
Street: $299
Manufacturer's Site: www.trdusa.com
Relevant Threads:
https://www.scionlife.com/forums/viewtopic.php?t=111965
https://www.scionlife.com/forums/viewtopic.php?t=59143
https://www.scionlife.com/forums/viewtopic.php?t=46137
This is the exhaust that is most likely to be found in your Scion dealer's parts department. TRD is a subsidiary of Toyota, so fit and finish of their products are almost always up to OEM standards -- this exhaust is no exception.
More of a cosmetic upgrade than a true performance improvement, but then again it is still an improvement. Exhaust tone is slightly louder, but not obnoxious. Idle note is deeper than stock, freeway drone is not too bad and full-throttle has a note of far more urgency.
Pricing is a little steep because it is sold through Scion dealerships, but you can occasionally find one online for around $250.00. Installation is straightforward and only takes a couple of minutes. Includes new gasket and all necessary hardware.
Pros: OEM Dealer option so can be financed with new vehicle, Toyota techs won't give you weird looks
Cons: OEM Dealer option pricing, everyone has one, not that much performance gain
Rating:
____
Old Apr 15, 2006 | 06:42 PM
scionlife's Avatar
Founder
OK guys, I got the ball rolling on this one... lets get all the information up here so that noobs can make easier decisions!!
Old Apr 16, 2006 | 01:00 AM
surfcity40's Avatar
ty
Old Apr 18, 2006 | 02:28 PM
coalhalo's Avatar
Thanks for the info. I'm definately a Scion noob and I'm trying to figure out some good exhaust and intake options.
Old May 10, 2006 | 09:51 PM
Jhhnn's Avatar
Just installed the TRD axleback on my xB, apparently I needed a refresher course in why I hate exhaust work....
Coupla tips. Don't try to pull the nut off of the pipe clamp- it's welded on. Pull the bolt instead. Spray some water into the rubber hangers before trying to remove the muffler- a little lube goes a long way. Soapy water would probably work even better.
It fits perfectly, with the tip naturally centered in the opening, and it's really not very loud, at all. I'm actually kinda disappointed... I've read that they get a little louder with age, so we'll find out...
I went with the TRD unit to avoid warranty issues, and because I didn't want it to be *too* loud or ricey looking. It's neither...
Old May 11, 2006 | 04:53 AM
XBoxDooDah's Avatar
Great, I'm getting ready for that move myself. Have done the YDR ram Air.
Old May 17, 2006 | 07:22 PM
GooseNaBoxxx's Avatar
I went with a Borla axleback. Not sure of the gains, it feels a little better. Its alot deeper than the stock exhaust, but not too loud. Of course, I kind of wanted louder so you knew I had a different exhaust, but if I rev it, those who own a stock xB can tell. I would recommend it, easy to install, came with a sticker (i did not put it on my box), and comes with instructions! Got it on eBay...give it a try.
Old May 17, 2006 | 08:04 PM
BUCKO's Avatar
Default TRD cat-back exhaust
I used to work for Borla Perf and they, at least back in 2000, made the TRD system. Given that that is still true i'd compare the price of those two kits. IMO i'd go with something cheaper as long as its a 'flow-through' design. The stock Scion exhaust is mandrel bent anyway so my guess is if your gunna keep the cats on (CA state legal at least) just replace the rear muffler. Save some flo $$$ if you dont have it to spend.
Old May 17, 2006 | 08:18 PM
BUCKO's Avatar
More TRD/ Borla info. It is true that the exhaust system will 'break-in' after time because the packing in the muffler will condense and not absorb as much sound (thus passing it through). As for worring about exhaust voiding your warranty, SEMA has lawyers that make sure there are laws in place to protect aftermarket parts manufacutres. To the best of my knowledge, law states that the aftermarket part would have to mechanically or in some logical way cause failure to a stock component. example. It is not logical that an exhaust system would cause your engine to 'throw' a piston or rod. In that sense they could not say that the vehicle (in whole) is out of warranty. Now if your muffler melts the rear fender then it could be justified that it was an out of warranty occurance. I'd suggest that you go to SEMA.org and educate yourself, it could help you as well the next time you get pulled over, it's not illegal to have aftermarket performance parts on your vehicle. most companies a registered though SEMA anyway so doing business with them is a good ideal.
Old Jun 4, 2006 | 02:21 AM
dmbrown79's Avatar
What is the stock inlet pipe diameter? Is it 2.50, 2.25. or 2.00?? I've seen them all. What's stock??
Old Jun 20, 2006 | 02:58 AM
Neebski's Avatar
Alright, this might be sad... So I just got my xb and I need some more power, I feel like im driving my go kart around town whats your best suggestion for a exaust? Im not to worried about the price anything works. Thanks!
Old Jun 25, 2006 | 01:42 AM
jpauletteUSAF's Avatar
Uh, no axleback exhaust for the xB is going to give you ANY noticeable power gains. The best axlebacks for the money are the Precision Muffler axleback and the Strup exhaust, IMO.
Old Jun 29, 2006 | 03:26 AM
HotBox420's Avatar
not much here to be calling it a buyers guide.
Old Jun 29, 2006 | 04:41 AM
Big_Bird's Avatar
DC Sports single canister axleback, will be getting the cat-bakc as soon as it comes out
well not a large power gain, but def more pep, and much louder than stocker, especially after i put in my Injen sri. Good quality, very easy to install and remove, i take it out, clean it and reinstall every couple months. Def worth the mpney for what you get.
Old Jul 4, 2006 | 12:01 AM
k_dub's Avatar
Hey wat about N.V.?
Get at me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 6, 2006 | 05:14 PM
ScionJazzy's Avatar
I have a DC Sports Axle-back exhaust too...I went to a muffler shop and got 2" piping installed as well....it's pretty sweet! Sounds good and you can feel a little more power.
Old Jul 8, 2006 | 06:30 PM
zdawg913's Avatar
im getting the TRD for my xA... and i am also getting a high-flow cat with resonator (magnaflow universal) to go with it. how much louder will that make the TRD exhaust? i have also ordered the Injen CAI.... all input welcome. thanks!
Old Jul 9, 2006 | 10:54 PM
CobraStngSVT's Avatar
Default ...
I think i have narrowed my options down to the GReddy or the Borla cat backs.
Anyone have any experience with the GReddy yet?
__________________
Old Jul 18, 2006 | 04:35 AM
Kiss's Avatar
I'm getting the GReddy SP2. It's only an axle-back though.
__________________
Old Jul 21, 2006 | 12:37 AM
Doctorsub's Avatar
Default Exhaust Me?
How are the Tanabe exhausts? Any word how well it matches with the Injen xb short intake?
