Someone post rear panel and door panel removal instructions?
Old Apr 19, 2006 | 01:42 AM
dmxsoulja3's Avatar
Default Someone post rear panel and door panel removal instructions?
Can someone post a link or info on what I will need to remove to get to the door speakers, and rear speakers, pics anything would be helpful.
Thanks, J
was going to let a shop do my instlal but I want to take my time and do it just how I want it
Old Apr 19, 2006 | 06:02 PM
dmxsoulja3's Avatar
nobody?
Old Apr 19, 2006 | 06:10 PM
chipzxb's Avatar
https://www.scionlife.com/forums/vie...+panel+removal
Old Apr 19, 2006 | 06:12 PM
dmxsoulja3's Avatar
that def helps some, thx for posting that link, now just need something for the rear and I'll be set....hopefully getting to the headunit is straight forward, pull the ***** and pry
Old Apr 20, 2006 | 03:17 PM
surfcitylocal's Avatar
Not exactly "pry" but close.
Remove the control ***** and the two screws found there.
start at the lower edges of the center trim piece and pull towards yourself.
Pull both sides loose.
Then pull the upper mounts. They will be a little tight the first time but they will come out.
Remove the three wire connections from the back of the center trim piece.
You'll have clear access to the head unit which is held in place by four screws.
Rear door panels come off just as the front ones. Remove screws and pull from the bottom edge. Good Luck.
Old Apr 20, 2006 | 04:30 PM
dmxsoulja3's Avatar
WOW thanks for the great pics and write up
lunchbx05
Dec 29, 2014 07:53 PM
Joeynenj
Nov 25, 2014 05:29 AM
McG_XB
22
Feb 10, 2004 09:53 AM
shaefner
Oct 8, 2003 02:48 PM
batute
Oct 7, 2003 04:20 AM
