ticking sound after 5k rpms...
how loud is the ticking
and dont free rev...
i suggest drive in 1st gear all the way up to redline slowly. and if you hear it then you have a problem...
but if not, i really tink you are fine
and the ticking could be from the intake (lower part) hitting the fender or watever.
and does this ticking noise happen when u bounce off the rev limiter? or when ur jus revving between 5-6k rpm
I have noticed for a little while now a ticking at ~70 mph on the freeway with slight amount of throttle just to keep speed. Any less (to slow down) or any more (to accelerate) and the ticking vanishes.
** Edit -- 7000rpm was in error
Originally Posted by Zero-Point
I have noticed for a little while now a ticking at ~7000 rpm on the freeway with slight amount of throttle just to keep speed. Any less (to slow down) or any more (to accelerate) and the ticking vanishes.
that is very interesting. i would like to know how to do this!
Again, I would suggest taking the car in to get checked out.. odds are its something minor, but in the unfortunate case that your bearing is spun... you might be lookin at a pretty penny if its not covered under warranty.
So does this sound only occur when you have the engine under load?
If you sit parked and give it a little gas and hear a ticking sound coming from the engine bay that is constantly ticking so long as you have your foot on the gas.. you might have the same issue that I had..
Regardless.. its best that you get it checked out if it gets either worse, or continues.
Hmm.. well honestly.. I dont think anyone on here can actually diagnose your car without hearing it in person.. bottom line.. if you have your warranty still.. which you should, I would have the dealership check it out.
unlimited77
Nov 11, 2004 02:29 AM
