New Wheels
Old Apr 22, 2006 | 10:38 PM
iRiSh_xB's Avatar
Default New Wheels
Alright guys, thanks for your help, I did go with the 215/45/17s, very clean look, I'm putting on the springs this week so looking foward to that.
Old Apr 22, 2006 | 11:30 PM
bBism's Avatar
your lugs are a 12x1.5 thread and would have to see the wheel before making a comment on the other
Old Apr 23, 2006 | 03:04 AM
YELOSUB's Avatar
Wagonistas
The offset of the rim is the question...I have 17 x 7 in a 40 offset with 215/40/17 and have ZERO issues...When my tires need replacing, I will be moving to the 215/45/17 tires to help fill the gap a lil' more...I don't think there are any vibration issues running a 215/45/17 tire...Have no clue about the lug issue...
Old Apr 23, 2006 | 04:24 AM
iRiSh_xB's Avatar
Well they told me that stock lugs would go on but it wouldn't be secure. So would I need a longer lug?
Old Apr 23, 2006 | 04:46 AM
cjastacio's Avatar
Your'e probably better off getting the tuner lugz. I beleive the stock lugz are too round at the base for the best contact with tuner wheels. By the way, why 215/45/17? According to 1010tires.com the best fit are 215/40/17. Any thoughts YELOSUB?
Old Apr 23, 2006 | 04:51 AM
iRiSh_xB's Avatar
I have had bad experiences with past wheels, with denting and what not. Living in NY the more sidewall the better.
Old Apr 23, 2006 | 06:32 AM
M-Flo's Avatar
45 is a taller tire. This gives more flex and shock absorbtion than a 40 tire so it will be more comfortable, and it will also fill the wheel well better giving it a more flush look.
There are trade offs in that your speedometer will be affected. Also it will be slightly heavier thus affecting mpg and acceleration in turn for a higher final speed.
Old Apr 23, 2006 | 11:20 AM
iRiSh_xB's Avatar
How would the tire size affect my speedometer?
Old Apr 23, 2006 | 11:33 AM
robbiej's Avatar
45 is a taller tire, taller then your stock tires so it will throw off speedo, odometer.
Old Apr 23, 2006 | 12:06 PM
iRiSh_xB's Avatar
Aren't stock 65s?
Old Apr 23, 2006 | 12:17 PM
robbiej's Avatar
185/65/15 195/55/16 205/45/17, see the trend? That is what Tire Rack or Americas Tire will tell you is your stock size, plus one size and plus two size, at least this is what I always got when I was searching tires and wheels for my car. If you vary much from this, then it will effect your speedo.
Old Apr 23, 2006 | 02:08 PM
dexter_5000's Avatar
or you can just use the miata tire size calculator http://www.miata.net/garage/tirecalc.html
Old Apr 23, 2006 | 02:46 PM
iRiSh_xB's Avatar
should the stock lugs be okay until i have a chance to pick up some tuner lugs??
Old Apr 23, 2006 | 03:15 PM
YELOSUB's Avatar
Wagonistas
^^^I would install the tuner lugs at the same time you put your new rims on...Im not sure if the stock lugs will work because #1. Fit the opening #2. Have enough thread rotations...Reference the 215/45/17 tire issue, there is a thread that discusses this issue...The 45 series tire from what I read gives you a nice ride with plenty of sidewall and it really fills the gap between the fender and tire nicely...As far as the speedo being off, it will only be off by a little bit so that wont be a biggie...Like I said, I have been rolling on 40 series for about a year now and I love they way they ride, but when my tires need changing, I will be putting on a 45 series...Good luck and lets see those pics when your done.....
Old Apr 23, 2006 | 04:15 PM
iRiSh_xB's Avatar
will do, thanks for your help.
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
EcoxA
Mar 18, 2015 03:45 PM
GoodVibes
Mar 3, 2015 09:47 PM
