drilling led holes
Old Apr 23, 2006 | 07:55 AM
dopexile's Avatar
Default drilling led holes
I have a minor gripe, I've been installing led's in my cupholders and my airvents... everything is going good except for the fact that when I push the leds through the holes it pushes thin plastic film through that gets wrapped around the led somewhat. I'd like to make more of a professional install look possible
The cupholders are easy to cut out because I can access the other side no problem, as are the middle vents, but I can't seem make the side vents look nice . I'm using a 3/16" bit, I notice the OEM led install guide says that you use use a "deburring tool" to clean out the holes but I haven't been able to find anything like that. Is there a tool or method that someone knows that will make for a cleaner LED install?
Old Apr 23, 2006 | 07:59 AM
bB2NER's Avatar
Music City Scions
To de-burr, just use a larger bit to clean up the edge of the hole you drilled.
Old Apr 23, 2006 | 08:41 AM
mwuf15's Avatar
how u get the oem led install guide? and where do u hook up the power?
Old Apr 23, 2006 | 09:09 AM
dopexile's Avatar
http://s86950156.onlinehome.us/00016...orlightkit.pdf
that's the light guide...
For power it's just connected to the cig lighter in front of the shifter with a panel switch on the positive line..
Old Apr 23, 2006 | 09:13 AM
tikbhoy's Avatar
read this guide too
https://www.scionlife.com/forums/viewtopic.php?t=22943
and read here for gutting your interior
https://www.scionlife.com/forums/viewtopic.php?t=60981
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
umnitza
Sep 1, 2015 08:06 PM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
stayintrucha
Aug 20, 2015 06:05 PM
10spokess
Aug 16, 2015 02:50 AM
