Big Brake Kit and What Wheel Size's Will Fit?
I know that with BBK's you have to have aftermarket wheels, but do they have to be bigger than 17" wheels. Is the fitment problem because of the actual spokes themselves and rubbing issues?
wow, did not know that. Does anybody know if WillWood will fit behind stock wheels?
Im most interested in Stoptech, i just dont like the look of Red calipers. They would be getting repainted, to a more mellow color, if i got them.
5mm spacer is the minimum to fit behind a stock wheel. I woudl recommend going 15mm in order to keep the wheels hubcentric and eliminate vibrations at highway speeds. As far as caliper color, red, black or silver paint are available at no extra charge with yellow, blue or gold paint costing extra.
Pic w/ stock wheels and 5mm spacer:
Pic w/ 17x8 +35mm Enkei RPF1...No spacer required:
Correct. I ran them with my stock wheels and they worked fine but the calipers were about as close to the wheel spokes as possible. I also had some vibrations at highway speeds that felt like a slightly out of balance wheel. Nothing dramatic, but it was noticeable nonetheless. If a 10mm hubcentric spacer was availble it would be perfect, but I know that the next size up from 5mm that H&R offers is 15mm.
that makes sense, i just happend to glance at thier applications....
i can get a 10mm spacer, there is a guy in fresno that makes them out of billet, we put them on a camaro, he also builds wheels. if your intrested i can ask.
With the amount of clearance I have I think you might be OK with the +45 offset in an 8" wheel. Theres quite a few shops that would likely have that wheel in stock...they can check the wheels withour wheel fitment template if you ask nicely I'm sure.
Heres a link to the template that gets cut out and put inside the wheel:
https://www.stoptech.com/tech_info/c...55-2430-02.pdf
scionlife
371
Jun 2, 2015 11:00 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
umnitza
Dec 1, 2014 06:26 PM
DenZinz
32
Feb 17, 2004 06:56 PM
