MAJOR ELECTRICAL PROBLEM!!!
Old Apr 30, 2006 | 04:33 AM
K_Dawg_ONE's Avatar
Default MAJOR ELECTRICAL PROBLEM!!!
Ok, having some major probs with my xB. Basically, here is the jist of it.
I noticed today that the following electrical does not work:
-speedo
-tach
-gas gauge
-power windows
-rear deforst
-a/c
-blower
-signals (however, four-ways DO work)
My radio DOES work as does my wipers and power locks. My headlights DO work as does my interior lighting (ie, gauge backlight, etc). My 'Door Open' light and all my other lights in the message center work just fine too.
To me, it seems that the car is not recogizing when the key goes past or in 'ACC' when i turn the car on. I beleive this cause when the car is actually running and i open the door, the door 'chime' goes off like the car is in 'OFF' and I left my key in.
We checked all fuses/relays today with the test light and they all were good. We even VISUALLY inspected all of them as well.
I cant go to the dealer cause, well, we dont have them in Canada and the Toyota techs havent been trained on the wiring.
Anyone else run into a similar problem or have any ideas? Thanks...
Old Apr 30, 2006 | 04:48 AM
ProshopXB's Avatar
Did you just come out one day and all this wasn't working or did you do a mod and this started?
Old Apr 30, 2006 | 04:53 AM
kentuc's Avatar
Check fuses and relays under the hood.
Old Apr 30, 2006 | 05:46 AM
stick_1NZ's Avatar
Yes, this can be a fuse or relay. Good luck.
Old Apr 30, 2006 | 12:53 PM
K_Dawg_ONE's Avatar
And yes, it just happened for no reason. I pulle my bBox out of storage about a week ago and everything has been running fine since then. I went for a coffee run yesterday, turned my truck off, went inside, and when I came back out and drove away. When i was sitting at the lights, i had my subs up loud and looked at my gauge cluster. Nothing was working so I thought that maybe I wasnt really paying attention to how I was driving and stalled out my Scion. Turned it off and restarted and that when I realized I had a problem. I work at a shop and we briefly checked it over (ie, fuses, relays, etc) and found them all to be good.
Like I said, it seems that the ECU is not recognizing the 'ACC' position on my ignition???
Old Apr 30, 2006 | 04:04 PM
K_Dawg_ONE's Avatar
Anyone?
Old Apr 30, 2006 | 04:09 PM
ProshopXB's Avatar
You try taking the steering column of yet and making sure that all the ign and acc wires have voltage?
Old Apr 30, 2006 | 05:26 PM
K_Dawg_ONE's Avatar
^Im glad your saying that. I was thinking of doing the same actually...glad someone is thinking like me (good to know that im NOT out to lunch...hahah)
Old May 1, 2006 | 12:56 AM
BrianxB's Avatar
report back with findings on the Ign switch. Also, check your alternator voltage while the car is running.
Is anything hooked to your ignition switch wiring or other wiring in the car that could be backfeeding ?
Old May 1, 2006 | 01:22 AM
superfreestyle's Avatar
DeepSouth Scions
your "message center" lights are tied into the second ignition so unless something is crossed then that rules out the ignition. i have installed about 6 alarms on scions, 3 of which were remote start so i am very familiar with what is on which ignition.
Old May 1, 2006 | 03:41 AM
phocis850's Avatar
Turn the key to acc. If the lights don't come on, the problem is either ignition switch, or the wires leading up to the ignition switch.
Old May 1, 2006 | 12:27 PM
K_Dawg_ONE's Avatar
Ive got a Compustar900 in my bBox...my boss thinks it has something to do with that, but, ive had it for over a year with no probs. Why now I wonder?
Old May 1, 2006 | 02:57 PM
Max2k's Avatar
Warranty issue?
Old May 1, 2006 | 04:00 PM
DeepSouth Scions
thats the same one that i have in mine.... check your wires on your steering column... is someone used butt connectors and didnt get a good crimp on the wires then one may have come loose but if they used t-taps it is not likely.....
if you second ignition is in fact not getting power then your cooling system will not come on and you could overheat the motor.... turn your a/c in and let it idle and listen for the electric cooling fans to kick on.
Old May 2, 2006 | 09:34 PM
usdmbB's Avatar
I would think it has to do with your alarm, Check ign. wire's where alarm is interfaced.
Alarm could be bad as well.
Marvelicious
May 1, 2015 08:00 PM
AxRxP
Jan 18, 2015 05:43 PM
TheTripleC
Jan 4, 2015 06:46 PM
BlueBox
14
Jan 15, 2004 01:08 PM
Opr8r
15
Oct 6, 2003 05:07 PM
