Is jet hot coating the answer for F/I people?
Old May 1, 2006 | 04:31 AM
jwaggz82's Avatar
Default Is jet hot coating the answer for F/I people?
http://www.powdercoater.com/jethotprices.htm
Is this the answer to the stop of the seal issue?
Everybody comment!
Old May 1, 2006 | 04:43 AM
jwaggz82's Avatar
JET-HOT JETHOT Jet Hot header coating.
Old May 1, 2006 | 06:08 AM
BlkSandPrlTurbotC's Avatar
I have a JetHot 2000degree FlatBlack finish on mine...I love it
Old May 1, 2006 | 07:29 AM
tikbhoy's Avatar
you could always wrap it if you have the patience to do it.
Old May 1, 2006 | 01:31 PM
HighlanderMac's Avatar
You may want to go and read the S/C thread again, cause so far I have found no seals that could warp because of the excessive heat.
Old May 1, 2006 | 04:47 PM
paul_dezod's Avatar
Scionetics
KAD
We offer Jet Hot coating for SL customers 10% off Jet Hot listing prices.
Old May 1, 2006 | 06:15 PM
Nice deal.
Not to mention getting a JetHot finish is pretty PIMP too. Wrapping looks like POO under the hood, if ur going to do it right, get it treated by JetHot
Old May 1, 2006 | 09:37 PM
nester's Avatar
We recommend ceramic coating, and we use it on most of our project cars. Not only does it provide a performance benifit, but it looks cool!
Old May 1, 2006 | 09:38 PM
nester's Avatar
Old May 1, 2006 | 09:44 PM
toastbox's Avatar
HOLY CRAP does that look sexy (drool......drool)
Old May 1, 2006 | 09:50 PM
SO-CAL_TC's Avatar
Can I spray paint a down pipe w high tamp paint or would it have to be jet coated as well
Old May 1, 2006 | 10:34 PM
Garage1217's Avatar
Jet hot's office is about 5 minutes from me. Will check it out and see if they have some good info for us. Also on that leak you guys have, I would just clean the oil up and pack some honda bond in the space the oil is coming out just to stop the leak. Easy fix for it is doing no other harm.
Only other thing I can think of is the oil is not draining quick enough in your cars for some reason and is pooling up inside the sc housing causing it to seep out anyplace it can.... Similar to a turbo leaking out the seals when oil does not drain quick enough.... The drain tube is pretty freakin small for the amount of oil being injected into the sc...
Old May 1, 2006 | 11:29 PM
jwaggz82's Avatar
well this is a start - what we really need to find out is whats causing the oil to come out. how much better is jethot then ceramic?
Old May 2, 2006 | 12:33 AM
Whocares05050's Avatar
Old May 2, 2006 | 04:10 AM
https://www.scionlife.com/forums/vie....php?p=1534979
^click that
Old May 2, 2006 | 04:12 AM
That 2nd pic of the blue finish appears to be blistered and splitting
Old May 2, 2006 | 04:26 AM
Max's Avatar
Max
Looks like casting marks to me.
Old May 2, 2006 | 07:07 AM
tikbhoy's Avatar
sorry i prefer to save money and use more of it on something else.
function > form
Old May 2, 2006 | 05:29 PM
paul_dezod's Avatar
Scionetics
KAD
Notice the texture and inside and out coating of Jet Hot.
JET-HOT 2000™ - Formulated for very high temperatures, this rugged coating protects substrates up to 2,450°F, heat levels sometimes encountered in Rodding and Off-Road applications. Available in black, blue or grey.
Old May 2, 2006 | 06:28 PM
Rasta's Avatar
I Used Performance coating on my exhaust housing and it looks real nice. It handles up to 2000 deg also and comes in a lot of other colors than jet hot plus I think it looks nicer. I did my housing in satin grey ice and it looks sweet. I am wrapping my down pipe with black header wrap. I will post pics of the housing later. Check it out at www.performancecoatings.com
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
greytc
Jan 12, 2015 09:49 PM
cavalierkid888
Jan 8, 2015 04:42 AM
hotroddelux
Dec 3, 2014 11:33 PM
Opr8r
20
Feb 25, 2004 11:29 PM
