lowering springs/rims & tires
Old May 3, 2006 | 05:52 AM
downforcexb's Avatar
Default lowering springs/rims & tires
I was wondering if i lower my xb with a TEIN S-Tech lowering spring kit and put a set of 15" rims what size tires could I Rock on my xb so it would look phat without having to sacrifice the ride(by the way it'll be a 2"inch drop)what size tires could i use and would it look slammed with a 2"inch drop and 15"rims?
Old May 3, 2006 | 05:56 AM
Nozerider's Avatar
It won't looked slammed with 15". When you lower the car, the ride quality will diminish.
Old May 3, 2006 | 06:34 AM
OldYeller's Avatar
I have 17's with my Tein S springs. I like the ride. It is a little rougher (bumpier) than the stock ride, but it corners a lot better.
Old May 3, 2006 | 02:38 PM
LEDMods_net's Avatar
Strictly Scionized
I agree, it won't be as comfortable, but it will look a lot nicer and perform better with the Teins. I also recommended larger than 15's.
Old May 3, 2006 | 04:38 PM
RTon20s's Avatar
If you are planning to get a new set of 15" wheels, get something wider with a lower offset. Something that will look more flush. That is the only was a 15" wheel looks really good on an xB.
As far as the tire size, keep it as close as possible to stock diameter. If necessary you could run a mild stretch on the tires to aid in preventing rubbing.
Old May 3, 2006 | 05:02 PM
craigxb's Avatar
this is 15" with tein H techs. this is my friends car and I believe he is running 195/50/15 tires stretched out to the max.
evolving_machine
Oct 21, 2023 01:16 PM
terrye
Jul 11, 2015 11:54 PM
scionlife
371
Jun 2, 2015 11:00 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
STCxB
11
Jan 9, 2015 04:30 PM
