mind the gap
Old May 4, 2006 | 11:37 PM
Slags77's Avatar
Default mind the gap
i ordered a wheel and tire package, thought i was getting P205 50 R16 but i got 40. maybe i'll get new tires. also, whenever i've ordered wheel+tire combo's in the past they always come with those hub centric rings, these didn't have them, is it bad if i don't use them. how can i tell if i need them? thanks
[/img]
Old May 4, 2006 | 11:38 PM
stick_1NZ's Avatar
WTF???
Old May 4, 2006 | 11:55 PM
hotbox05's Avatar
holy crap did you raise the car ? i dont remember my stock xb being that high. just realised they came with the wrong series tire
Old May 5, 2006 | 12:03 AM
hayalex6's Avatar
holy ____ batman, that's gap is huge.
where'd you order that crappy package from? They definetly should have come with hubcentric rings.
This is why ordering from discount no name places can cause a problem. When I ordered my package from TireRack, they double checked everything about the sizes, included hubcentric rings already installed, and new lug nuts.
Did this place even balance your tires?
Old May 5, 2006 | 12:10 AM
Slags77's Avatar
thanks for the responses. i feel much better. :?
yep, they came balanced. the package was 699 shipped w/Ventus Hankook tires. so i guess its bad not to use the rings? the rims seemed to fit alright. i can't tell
Old May 5, 2006 | 12:21 AM
Nozerider's Avatar
My ride isn't dropped yet yours is way higher than mine.
Old May 5, 2006 | 12:31 AM
hotbox05's Avatar
if your wheels start vibrating then you need hubcentric rings. if not you're good to go.
hankook? run away from those tires.
Old May 5, 2006 | 01:17 AM
RaginCajun's Avatar
I have hankooks, not bad tires. Is it me or does the rears look smaller than the fronts? If you were to slam that rig it would be wayyyy low.
Go ahead and put the rings on, they wont hurt a thing.
Old May 5, 2006 | 01:29 AM
magicmanjk808's Avatar
assuming those are rota slipstream, you will need hubcentric rings..
Old May 5, 2006 | 02:47 AM
hotbox05's Avatar
send the package back and get the right 50 series tire.
Old May 5, 2006 | 02:51 AM
hotbox05's Avatar
hankooks from my own and close friends experiences suck. blow outs , total tread seperation , chunks of treads randomly coming off from just one tire. chunks coming off from all tires. bubbles in teh sidewall. bad bad stuff. never again will i go hankook or nankang.
Old May 5, 2006 | 03:14 AM
hayalex6's Avatar
With tires, you get what you pay for. I'll always stick with the quality brands like BFG, Pirelli, etc.
Old May 5, 2006 | 03:15 AM
Slags77's Avatar
no i didn't raise the suspension and the wheels are both the same size maybe its my camera?!?
i can't drop the car because when i load it up with my band equipment it sits pretty low.
Old May 5, 2006 | 03:19 AM
hayalex6's Avatar
get the right size tires, then get h-techs or s-techs.
Old May 5, 2006 | 03:22 AM
dugzilla's Avatar
that looks strange.
Old May 5, 2006 | 03:29 AM
Slags77's Avatar
is it bad to change the springs and not the struts?
Old May 5, 2006 | 03:31 AM
the struts won't last as long, but i wouldn't say it's bad.
Old May 5, 2006 | 08:57 AM
hotbox05's Avatar
not exactly. those tires may have higher quality but treadwear , noise , grip may not be as good as others let alone their extra price. i just stay away from hankooks , nankangs , and dunlops.
Old May 5, 2006 | 10:10 AM
cyergey's Avatar
Looks like your rolling on 12's
Old May 5, 2006 | 11:12 AM
mill0048's Avatar
I doesn't seem like anyone answered your question about the hub centric rings. If you don't have them, your wheels will be mounted off center of the hub and will cause vibrations at speeds of ~50mph or greater. They're cheep to get. You can get them thru Tire Rack in plastic or metal for $15 I think.
As for the lowering springs without shocks, you'll wear out the stock shocks fast that way. That's what I did. Within several months I had to get new shocks too. As for loading my lowered car with aftermarket shocks and springs, my new weight limit is around 650lbs compared to the stock 800lbs.
I'm running 205/50R16 too. The 50 series will help fill your wheel well a bit more (about a half inch larger than the 40 series all around), but no where near as much as lowering.
