mind the gap
Old May 5, 2006 | 12:31 PM
hotbox05's Avatar
Originally Posted by cyergey
Looks like your rolling on 12's
lol.
Old May 5, 2006 | 12:33 PM
hotbox05's Avatar
Originally Posted by mill0048
I doesn't seem like anyone answered your question about the hub centric rings. If you don't have them, your wheels will be mounted off center of the hub and will cause vibrations at speeds of ~50mph or greater. They're cheep to get. You can get them thru Tire Rack in plastic or metal for $15 I think.
As for the lowering springs without shocks, you'll wear out the stock shocks fast that way. That's what I did. Within several months I had to get new shocks too. As for loading my lowered car with aftermarket shocks and springs, my new weight limit is around 650lbs compared to the stock 800lbs.
I'm running 205/50R16 too. The 50 series will help fill your wheel well a bit more (about a half inch larger than the 40 series all around), but no where near as much as lowering.
your weight limit should have stayed the same , what makes you say a 200 lb reduction.
Old May 5, 2006 | 03:47 PM
RaginCajun's Avatar
Hankooks come stock on all new Ford F150s. They are a cheaper tire but that isn't always bad. Sometimes paying for a name is just that. Look at Firestone and what happened to them.
Old May 5, 2006 | 03:51 PM
hayalex6's Avatar
I don't trust anything car related from Korea....
Old May 5, 2006 | 07:38 PM
jerome829's Avatar
dude, is that car photoshopped?
that looks unreal!
Old May 5, 2006 | 10:02 PM
mill0048's Avatar
I use my car to transport boxes of documents. I also go to lunch with some people that are 'big'. Stock, I used to be able to carry 4-5 people or ~650lbs of boxes without bottoming out on bumps. Now (with S-Techs and Koni Yellow Sports), I bottom out on bumps with 3-4 of those same people or ~500lbs of boxes. Try telling people (your friends) you can't drive because of weight limits.
But for Slags77, H-Techs (1.2"-1.5")might be a good route if he wants a drop.
Old May 6, 2006 | 02:50 AM
Slags77's Avatar
$400 dollars later and fixed.
and i found out that i don't need hub centric rings because apparently the speedy race mode wheels are application specific.
i think i'll stick to the stock suspension for now b/c i'm broke
thanks for the input everybody
Old May 6, 2006 | 06:20 AM
magicmanjk808's Avatar
wow, the tires make a huge difference
Old May 6, 2006 | 12:35 PM
mill0048's Avatar
Big difference, looks great!
Old May 7, 2006 | 02:48 AM
OldYeller's Avatar
Default Re: mind the gap
Originally Posted by Slags77
i ordered a wheel and tire package, thought i was getting P205 50 R16 but i got 40. maybe i'll get new tires. also, whenever i've ordered wheel+tire combo's in the past they always come with those hub centric rings, these didn't have them, is it bad if i don't use them. how can i tell if i need them? thanks
[/img]
Dude--did you forget to lower the jack? This is totally bizarre. As for the hub centric rings===they came with my package from www.treadepot.com. Good luck!!!
Old May 7, 2006 | 01:01 PM
xBster's Avatar
the new tires look great! wow..the first tires scared me.
Old May 9, 2006 | 08:56 PM
KenzokuXB's Avatar
Wow! That gap looked worse then some girls from the Tenderloin District in SF. LOLZ! J/K!
Way better with the 50's on there.
yhwhdesign
Jun 11, 2021 03:34 PM
lvlonkey
Sep 22, 2016 02:23 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
Bhikku
Sep 16, 2015 10:57 AM
Bimfi
Sep 4, 2015 08:15 PM
