Can it be use? Apex...
Old May 5, 2006 | 02:46 AM
soros151's Avatar
Default Can it be use? Apex...
Maybe a super noob question ahead, sorry to bother...
Can a Apex Super VAFC II be use to tune the VVT-i?
Old May 5, 2006 | 03:53 AM
Neothin's Avatar
I don't believe so... VVT-i can constantly change the valve timing throughout the RPM band vs that of VTEC that has 1 set RPM where it changes cam lobes. Something like the power enterprises cam con though, that can play with VVT-i.
Old May 5, 2006 | 03:58 AM
soros151's Avatar
So in short, I need the Cam Con to tune the vvt-i and the Apex Super SAFC II to tune the air/fuel...? WOW, thats like 600 bucks Then again everything costs..
Old May 5, 2006 | 04:04 AM
Neothin's Avatar
actually i don't think so... i only looked at the camcon briefly, but i think you can just plug in the a/f ratio you want and it'll lean/richen the fuel map to maintain that ratio.
Old May 5, 2006 | 04:08 AM
soros151's Avatar
So the Cam Con also helps to tune the A/F ratio??
Old May 5, 2006 | 04:13 AM
Neothin's Avatar
according to this you can control the VVT-I valve timing and adjust the a/f ratio:
https://www.scionlife.com/forums/viewtopic.php?t=115859
Old May 5, 2006 | 04:15 AM
soros151's Avatar
thanks
