Can it be use? Apex...
I don't believe so... VVT-i can constantly change the valve timing throughout the RPM band vs that of VTEC that has 1 set RPM where it changes cam lobes. Something like the power enterprises cam con though, that can play with VVT-i.
So in short, I need the Cam Con to tune the vvt-i and the Apex Super SAFC II to tune the air/fuel...? WOW, thats like 600 bucks
Then again everything costs..
actually i don't think so... i only looked at the camcon briefly, but i think you can just plug in the a/f ratio you want and it'll lean/richen the fuel map to maintain that ratio.
according to this you can control the VVT-I valve timing and adjust the a/f ratio:
https://www.scionlife.com/forums/viewtopic.php?t=115859
