Steering wheel slight pull to right
Old May 7, 2006 | 10:03 PM
jasper's Avatar
Default Steering wheel slight pull to right
Anyone new tC owner has this kinda problem? When driving straight, the wheel won't stay stright but pull slightly to the right. Should I just take it back to dealership and ask them to check the alignment?
Old May 7, 2006 | 10:17 PM
nytlemgr's Avatar
yes. not sure if they will do anything for you, but it is worth a shot. something as simple as hitting a pot hole can cause your cars alingment to be off.
Old May 7, 2006 | 10:19 PM
tikbhoy's Avatar
Default Re: Steering wheel slight pull to right
check your tire pressure first.
drive on a couple different road to make sure the road itself is even.
Old May 7, 2006 | 11:34 PM
jasper's Avatar
My pressure is alright, but I will defintely drive on different roads later to double check this.
Old May 8, 2006 | 01:15 AM
johnnywebb's Avatar
and do this soon... not correcting the alignment will chew up your tires FAST.
Old May 8, 2006 | 01:49 AM
paultg's Avatar
My new tC does this also. I have 3K miles on it now. I'm going to have the alignment redone under warranty when I bring it in for the first oil change.
Paul G.
Old May 8, 2006 | 01:59 AM
Hyghgynx's Avatar
When you first get your tC, it should slightly pull to the right. That's because if you fall asleep at the wheel, you don't drift into oncoming traffic. The pull should be ever so slight. If it pulls harder then that, have your alignment checked. Also if you lowered your car, that can cause a slight pull.
Old May 8, 2006 | 03:41 AM
jasper's Avatar
This is the first time I have ever heard about this. Btw, I just double check again the tire pressure, they are all about 42psi on Bridgestone 17" tires. I think the pressure are too high since manual said it should keep at 32psi front and 29psi rear.
Old May 8, 2006 | 05:28 AM
phungy's Avatar
Def too high.
Old May 8, 2006 | 07:05 AM
JOEinSD's Avatar
ive had 2 alignments done under warrnaty with this. the first time they fixed it but i came right back within 2 months. its a little better now but it's only been a couple of weeks since my last alignment. they told me that the aligment was definitely off and thy just put it back to spec for me.
Old May 8, 2006 | 08:39 AM
CatalepsicFox's Avatar
strange I actually have that too. Not sure if it's an alignment issue though.
Old May 8, 2006 | 02:30 PM
EnderSavesTheDay's Avatar
There's a toyota service bulletin on this. It may be alignment, it may be steering column.
more info here: https://www.scionlife.com/forums/viewtopic.php?t=105110
or particularly
Originally Posted by sciontc_mich
tsb for steering.. here are the three pages of the service bulletin..
now i know it's for steering pull, but it's clear that the pump design was redone and a new part is availble.. so i think it still does apply..
Page 1:
page 2:
page3:
Old May 8, 2006 | 04:23 PM
paultg's Avatar
Interesting info with at TSB. My car is a 2006 though.
Paul G.
Old May 8, 2006 | 05:34 PM
jasper's Avatar
Thanks you all for all those helpful information.
Old May 8, 2006 | 05:51 PM
brian's Avatar
i've had it since the day i got it back in 2004.
Old May 8, 2006 | 09:09 PM
JOEinSD's Avatar
oh yeah, forgot to mention the TSB. thanks ender.
Old May 9, 2006 | 02:12 AM
jasper's Avatar
so how's your tire tread? Are they still in good shape? I used to have a 99 accord with slight pull to right either, but luckily it didn't do anything on my tire's tread.
Old May 15, 2006 | 07:08 PM
SSQ's Avatar
SSQ
I have had mine for about 900 miles, and yeah, the steering wheel does tilt a bit to the right when going straight. Tire pressure checked, alignment done, but the same thing exist. Keep me posted if theres a fix for it.
Old May 15, 2006 | 07:19 PM
brian's Avatar
tires are fine. i have almost 20k on them and they look very good still, plenty of tread left.
Old May 15, 2006 | 07:21 PM
DouBLeJ16's Avatar
Mine goes slightly to the right also. barely noticable but it does happen.
