Steering wheel slight pull to right
Anyone new tC owner has this kinda problem? When driving straight, the wheel won't stay stright but pull slightly to the right. Should I just take it back to dealership and ask them to check the alignment?
drive on a couple different road to make sure the road itself is even.
When you first get your tC, it should slightly pull to the right. That's because if you fall asleep at the wheel, you don't drift into oncoming traffic. The pull should be ever so slight. If it pulls harder then that, have your alignment checked. Also if you lowered your car, that can cause a slight pull.
This is the first time I have ever heard about this. Btw, I just double check again the tire pressure, they are all about 42psi on Bridgestone 17" tires. I think the pressure are too high since manual said it should keep at 32psi front and 29psi rear.
ive had 2 alignments done under warrnaty with this. the first time they fixed it but i came right back within 2 months. its a little better now but it's only been a couple of weeks since my last alignment. they told me that the aligment was definitely off and thy just put it back to spec for me.
There's a toyota service bulletin on this. It may be alignment, it may be steering column.
more info here: https://www.scionlife.com/forums/viewtopic.php?t=105110
or particularly
or particularly
Originally Posted by sciontc_mich
tsb for steering.. here are the three pages of the service bulletin..
now i know it's for steering pull, but it's clear that the pump design was redone and a new part is availble.. so i think it still does apply..
Page 1:
page 2:
page3:
Page 1:
page 2:
page3:
Originally Posted by brian
i've had it since the day i got it back in 2004.
I have had mine for about 900 miles, and yeah, the steering wheel does tilt a bit to the right when going straight. Tire pressure checked, alignment done, but the same thing exist. Keep me posted if theres a fix for it.
