New belt for smaller SC pulley
Old May 12, 2006 | 01:32 PM
JT_Scion's Avatar
Default New belt for smaller SC pulley
Hey guys, i went up to my local auto store and told them the part number for the belt that everyone is buying after getting the smaller pulley.. but they weren't able to find it. Does anyone have any more detailed info on the belt, ie: what car/truck its for to help me try and find it?
Thanks again!
Old May 12, 2006 | 03:31 PM
Nick06tC's Avatar
5.4l Jeep Cherokee serpentine belt I believe
Old May 12, 2006 | 03:37 PM
kytc's Avatar
If you're running a smaller pulley from ZPI the goodyear gatorback probably won't work. I tried it and it didn't work, it was too small. I found another belt that works with the ZPI pulley so if you need it I can try and find it. It's a poly cog just like the goodyear but cheaper and fits with the ZPI.
Old May 12, 2006 | 03:43 PM
JT_Scion's Avatar
yea, i have the zpi pulley. if you don't mind , i'd appreciate the info on it when you get a chance. Thanks!
Old May 12, 2006 | 03:49 PM
kytc's Avatar
I'll get that for you tonight. If you don't mind me asking how much was your battery kit from ZPI?
Old May 12, 2006 | 05:34 PM
yellot00tr's Avatar
the gatorback belt worked-it's a little annoying to put on, but it stretches to fit.
Old May 12, 2006 | 08:59 PM
kytc's Avatar
My dad and I both worked on it and it wouldn't work. Maybe I got a smaller one or something but there was no way it was going on mine
Old May 12, 2006 | 10:16 PM
Simplyscion's Avatar
Team No Limitz
I got the gatorback on my stock pulley right now as we speak
Old May 12, 2006 | 11:50 PM
kytc's Avatar
Idk unless I got the wrong size or something which is a very good possibility knowing my memory skills, lol
Old May 13, 2006 | 06:58 PM
hPower's Avatar
Courtesy of the pulley experts over at www.NonStopTuning.com
Enjoy
http://www.nonstoptuning.com/infoPageBelts.htm
Old May 13, 2006 | 07:11 PM
Team No Limitz
thats why we love these guys...once again NST for the win
Old May 20, 2006 | 09:44 PM
wtc_81's Avatar
Default zip or nst??
I know htat zpi makes a pulley and I guess nst does as well.. Anyone see any issue with useing a differnt size pully besides a lil increase of HP? I will some time next year get rods and pistons. and I looked on the list I would have to ge the belt that says sc trd sc right? thanks for the info.
Old May 20, 2006 | 09:50 PM
Garage1217's Avatar
2260mm is the length you want. Or 2265 longest with either pulley. This number is usually on the package...
And of course I reccomend the NST pulley as you will have it in a very quick fashion as opposed to the other pulley on the market that they mine the metal first, then process the metal, then send it off to be machined, then mabey someday it will arrive to you..
Old May 22, 2006 | 01:07 AM
wtc_81's Avatar
Default oil leak
Is it true that the s/c's link with the other pulleys?
Old May 22, 2006 | 02:49 AM
hPower's Avatar
I think the 2260 is a good fit. This is the same as K070890.
Old Jun 5, 2006 | 03:03 PM
IceNine's Avatar
Does NST's pulley *require* a belt change, or can you use the one that comes with the SC?
Old Jun 5, 2006 | 04:45 PM
PghtC's Avatar
smaller pullies require a belt change no matter if it is NST or ZPI.
I don't know what this means.
Old Jun 5, 2006 | 04:48 PM
IceNine's Avatar
Any decent how-to's on changing the belt?
Old Jun 5, 2006 | 04:50 PM
PghtC's Avatar
loosen tensioner by putting a wrench on it and pulling, then slide belt off. Pretty simple. Hardest part is getting a wrench in there that is long enough to get leverage on and not hit anything that is in the way.
Anyone know what boost level the zpi pulley produces anyway? It just says on their website it increases the HP by 21HP, and allows you to run more boost. That's generic.
Old Jun 13, 2006 | 12:21 AM
IceNine's Avatar
FWIW, I used a 2265 length Gatorback, works fine.
