Subwoofer Problem
Old May 13, 2006 | 07:04 AM
brownbanana's Avatar
Default Subwoofer Problem
I recently installed my new sounds in my new custom amp rack. All of the components I am using are the same except for the new subwoofer amp & enclosure. The headunit, front components, rear coaxials, subwoofer, and 2-channel amp for fronts are the same as before. Everything was working fine (except for a little engine whine, yup ground problem) until last night when I was playing my music pretty loud, the subwoofer shut off. All the other speakers are working just fine and my connections seem to all be okay. The amp is still on as the LED indicator still turns on. What could be my problem? sub broke? amp broke? thanks
Old May 13, 2006 | 02:01 PM
SCI_TC_GUY's Avatar
physically check all rca's and speaker wires (at HU, amp, and sub)... make sure the LED indicator is the "on" and not the "protection" light...
Old May 13, 2006 | 02:08 PM
dragonheart364's Avatar
Try redoing the ground if it was a bad connection to start with, also are all your speakers amped or just the sub? If its just the sub check the connections inside the box too.
Old May 14, 2006 | 12:11 AM
scottle's Avatar
the ground could be bad and not producing enough. or the wire on the sub got loose. pull the sub out and check it
Old Sep 3, 2006 | 05:00 AM
Taugenichts's Avatar
I have a problem like brownbanana's. I just installed the sub from my (home) surround sound system (100w, 4 ohm) in my xB with a 240 watt, 4-channel amp that i got free from a friend. I spliced into my right rear speaker, connected a 2-channel high-to-low converter, and then ran the rca's into the amp from there.
To power the amp: power wire from battery to power-in, spliced into accessory wire in ignition harness for REM, and grounded to a bolt that connects the rear right speaker to the body.
My question is... whats the most likely reason that my sub keeps shutting off anytime i turn it up to high, but then comes back on if i restart the HU? It's driving me crazy cause I can't figure it out. I was wondering if it has to do with the fact that I spliced into the rear wire and maybe there isnt enough power? I doubt that I need some kind of capacitor cause the sub is such small wattage, but what do you guys think?
Old Sep 3, 2006 | 03:10 PM
3min3m2's Avatar
thats wierd...mine only does that when my amp overheats(its in a bad spot, it has 2 fans, but its kinda sealed....lasts about 1.5 hrs of hard hitting before it goes....and boy it gets hot)
i have had my subs bounce the wires loose inside the box....that was funny to see, soldered them to the sub, and plugged them bak in, no probs since then....check connections if amps good, thats all i know
Old Sep 3, 2006 | 08:48 PM
tc876's Avatar
i have problem about my sub 2 , i blow 3 subs already , but i dont know why , i just have the eclipse sub , and i put it on just on day and its blow , is that some thing wrong with the scio ? because my friend have this problem 2
Old Sep 5, 2006 | 11:41 AM
SCI_TC_GUY's Avatar
taugenichts, I'd say you've probably got the sub wired wrong at the amp and you're driving the amp into protection mode.
tc876, subs don't just blow, there's always a reason. Do you have your gains set properly? what model amp and sub do you have? What impedance configuration is your subwoofer?
Old Sep 6, 2006 | 05:28 PM
tc876's Avatar
i have the sony 1400w sub and sony 1400w mono amp , and its blow 3 speaker already , i bring to the audio shop let them install but its still blow , i dont know why
Old Sep 6, 2006 | 06:11 PM
SCI_TC_GUY's Avatar
are your gains set properly?
Flyfishfreak
Jun 10, 2016 02:55 AM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
herwig
Mar 23, 2015 04:19 AM
CONCRETETC
Feb 9, 2015 08:05 PM
toyotaisme
Jan 10, 2015 10:24 PM
