Void Warranty?
Old May 14, 2006 | 05:55 AM
20tCDude05's Avatar
Default Void Warranty?
I am gonna get a Super White tC in a few weeks, and I wanna add koni shocks/struts or TRD shocks/struts with Tein S-Tech springs within weeks after getting it. I am only afraid of the warranty if something bad were to happen which would result into expensive repairs, depending on the severity of the damage. What should I do? I REALLY wanna do this ASAP.
Old May 14, 2006 | 06:12 AM
toastbox's Avatar
What you should do is use the search button, its the bright red button labeled SEARCH. You should search for "Moss Magnussen" and you should read that shizzy.
I don't mean to be an a$$ but this has been answered so many times it makes me want to throw up.
Old May 14, 2006 | 06:18 AM
ToneDeaf's Avatar
Until recently I did not know there was such a thing as Moss Magnussen. My fault? Probably.
However, a simple answer or polite response directing somone where to search may have been more appropriate.
And by the way, no one cares what makes you vomit.
Tone Deaf
Old May 14, 2006 | 06:19 AM
20tCDude05's Avatar
Sorry...
Old May 14, 2006 | 06:27 AM
toastbox's Avatar
Tone Deaf
whatev.
Old May 14, 2006 | 06:29 AM
toastbox's Avatar
Originally Posted by 20tCDude05
Sorry...
I probably could have phrased that better....sorry if that came across as a-hole-ish.
Old May 14, 2006 | 06:35 AM
surfcity40's Avatar
i love when folk self moderate.
Old May 14, 2006 | 06:40 AM
20tCDude05's Avatar
Haha, let's stick to the topic here.
Is it a bad idea to do this within weeks after I buy the car?
Old May 14, 2006 | 06:45 AM
toastbox's Avatar
no problem at all. Moss/Mag states that your warranty is valid, regardless of aftermarket parts, unless the dealer can prove in writing, that the parts in question were responsible for any damage.
bottomline, those parts are fine to install, no warranty issues.
Old May 14, 2006 | 07:01 AM
OldYeller's Avatar
If they are installed wrong they may cause problems with the warranty.............
Old May 14, 2006 | 07:29 AM
20tCDude05's Avatar
Is there any detailed guidelines or thread WITH pictures on a full suspension swap? As in shocks and spring swap?
Old May 14, 2006 | 07:38 AM
toastbox's Avatar
again, the search button is your friend. Or even browse the tech forums. General rule of thumb, 90% of the stuff a person would want to know about, has already been asked before. Using th search button prior to asking will not only save you the time of composing your message, it'll save you the tiem of waiting for a response.
Old May 14, 2006 | 07:47 AM
20tCDude05's Avatar
I did check the tech section a while back and there was nothing on suspension unless if I am wrong.
Old May 14, 2006 | 04:24 PM
Yanki01's Avatar
the koni shocks will run you around $700. the tein's will run around $170. then you have to pay for install. I would say if you have the cash, go with coilovers! the tein basics will run around $860? it would save you money and you get to adjust the ride hight too! Thats what i would do if i had the cash!!
BTW the search button is your friend, it would save you alot of time!
Old May 14, 2006 | 08:16 PM
brian's Avatar
koni yellow + s-techs will be a better performing combo then the basics. and yellows will run you into high 500s, shouldn't be 700. i know, because i almost went that route.
Old May 14, 2006 | 08:28 PM
20tCDude05's Avatar
I just might get the TRD shocks. Because they work good enough I suppose.d I am not trying to get the best of everything, just improvements, I want good improvement with the drop tho.
gas_meet_foot's Avatar
+1
Not only will this combo have a better ride for the street, the konis are two-way adjustable. The Tein Basics are only height-adjustable.
Old May 14, 2006 | 09:14 PM
20tCDude05's Avatar
What do you mean two way adjustables? Does Koni make more than 1 set for the tC as in the Sport and then I hear about this Yellow. I'm confused.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Luisfc1972
Scion tC 1G Wheel & Tire
10
Oct 23, 2015 05:49 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
carid
Aug 7, 2015 11:32 AM
