INSTALLED MY GREDDY STRUT BRACES.... THEY LOOK NICE!!!!
The front bar seems to be looks only, I could get no movement out of it when jacking up and down the car. Fit and finish is perfect.
The rear bar definitly should make some kind of difference, noticable or not. When jacking up the car even from the centerpoint, I could visually see the bar ends slide in there housing when it was loose. I jacked the car off the ground, torqued down the bolts super hard and dropp the car. The bar is tight as can be and you can feel the tension when grabbing it. Anyways good buy! Here are some pics...
Rear bar required light cutting of the side panels to make fit correctly.
Well you have a rear sway bar to help with body roll and understeer, and you also have a rear strut tower brace which is pictured which simply helps with body flex under hard load... Mostly just looks though..
hampton1100
Jan 2, 2015 08:13 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
