fuel
Old May 15, 2006 | 05:30 PM
fat-boy's Avatar
Strictly Scionized
Default fuel
I want to get the purren fuel rail and bigger injectors what ones should I use
Old May 15, 2006 | 05:41 PM
milesm4's Avatar
RC injectors are good
Old May 15, 2006 | 06:10 PM
fat-boy's Avatar
Strictly Scionized
what size shold i use
Old May 15, 2006 | 07:46 PM
DarkBoxJr's Avatar
If you don't have a turbo or supercharger, don't.
Old May 15, 2006 | 07:59 PM
fat-boy's Avatar
Strictly Scionized
y not
Old May 15, 2006 | 11:51 PM
RTon20s's Avatar
Because as I understand it, unless you are adding more air along with the fuel, you won't see any gain. You have to match the additional fuel with air. If you don't you will be running rich, and the sensors will pick that up. The sensors will tell your ECU, which will in turn attempt to lean up the fuel being squeezed out of those bigger injectors.
End result? Several hundred dollars down the drain with nothing to show for it power wise.
Old May 16, 2006 | 01:14 AM
ProshopXB's Avatar
Well said Dustin, as always. ^^^^^^^^ +1
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
