do these fit on stock tires?
Old May 16, 2006 | 08:29 PM
melvynray's Avatar
Default do these fit on stock tires?
Flik Fuel (gloss Black)
PCD: 5x100
ET: 42
<<< will these fit on the stock potenzas?
Old May 16, 2006 | 08:30 PM
ack154's Avatar
Yes.
Old May 16, 2006 | 08:32 PM
melvynray's Avatar
ok. thats all i wanted to know. appreciate it! i only want them cause there nice for 79 bucks a piece.. you can delete or lock this post if u want now. :-)
Old May 16, 2006 | 11:05 PM
surfcity40's Avatar
yeah, saw that at edge racing. did you check out the 18" packages? some awesome bundles as well.
Old May 16, 2006 | 11:57 PM
melvynray's Avatar
my prob is i hate rubbing.. and my car is extremely low.
Old May 17, 2006 | 02:44 AM
surfcity40's Avatar
changing the rim height will generally not affect "rubbing" because as the wheel height is increased, the "aspect ratio" of the new tire is lessened. this means that the overall height of wheel and tire together remains the same regardless of whether the wheel is 17", 18", or 19". the height (aspect ratio) of the tires changes to accomodate the taller wheel.
so, if done properly, if you stood a ruler from the ground to the top of the tire, the measurement could pretty much be the same whether the wheel itself is 17', 18" or 19" tall.
Old May 17, 2006 | 02:45 AM
brian's Avatar
you're gonna keep the stock tires....? i would swap out for better ones
Old May 17, 2006 | 06:16 AM
theblue's Avatar
Kind of offtopic but hell..
How much would you spend for some new tires that would fit on the stock rims if its just a daily driver?
Old May 17, 2006 | 06:21 AM
RedneckwithanxB's Avatar
for the 17's you can get some great tires for ~$60 a peice
check www.edgeracing.com
those Fliks are pretty swwet Mel, good luck
Old May 17, 2006 | 06:40 AM
exige's Avatar
following
Old May 17, 2006 | 08:31 PM
melvynray's Avatar
i hope they will look good.. $60. which ones?
scionlife
371
Jun 2, 2015 11:00 PM
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
TJ
10
Apr 15, 2006 05:12 PM
