19s and Potholes?
Old May 20, 2006 | 02:50 AM
20tCDude05's Avatar
Default 19s and Potholes?
I am thinking about going with 19s, but I was told that as you run larger rims, you have to run with thinner tires unless if I am mistaken, so I am concerned about hitting or even bending the rims from potholes or whatever that could cause it. Has this happened to anyone running on 19s?
Old May 20, 2006 | 02:53 AM
ack154's Avatar
It can happen with any wheel really... but it's more common with larger wheels and lower profile tires.
I had a friend that flatspotted one of her 18" TRD wheels on an xA.
Old May 20, 2006 | 02:54 AM
OldYeller's Avatar
Its not the size of the wheel so much as the profile of the tire..........
Old May 20, 2006 | 03:01 AM
pollup's Avatar
on my geo i had 18's and i hit a pothole and the rim sliced the outer wall of the wheel. it happens.
Old May 20, 2006 | 03:03 AM
ack154's Avatar
^ Wait... did you just put "geo" and "18s" in the same sentence?
Old May 20, 2006 | 03:06 AM
Max's Avatar
Max
Since it has not been directly stated: Yes, you will need to run a shorter sidewall. A larger tire will not fit. The outer diameter of the tire is the same, but the wheel is taking up more room, so your sidewalls must shrink to accomodate.
Old May 20, 2006 | 03:08 AM
pollup's Avatar
yes rofl, i was younger, but i had an original geo. look for yourself
http://www.cardomain.com/ride/132933
sponsored by erebuni and mag graphics.
Old May 20, 2006 | 03:23 AM
20tCDude05's Avatar
So, it would have to be a tire size of either 215/35/19 or would 225 be safer?
Old May 20, 2006 | 03:28 AM
20tCDude05's Avatar
Old May 20, 2006 | 03:30 AM
pollup's Avatar
hey that geo had more invested then your car is worth. nuff said .. was a fun car.
Old May 20, 2006 | 03:31 AM
tC9o9's Avatar
19" + pothole = POP
Old May 20, 2006 | 03:32 AM
20tCDude05's Avatar
So, what tires size should I run on? It's either 215/35/19 or 225/35/19 and it will be the Toyo Proxes 4. Which would be safer?
Old May 20, 2006 | 03:34 AM
20tCDude05's Avatar
Originally Posted by blackonblacktc
19" + pothole = POP
Ouch, that hurt. The tC's tire fenders kinda look too wide, so I feel if I get 18s, it will make the 18s look smaller.
Old May 20, 2006 | 03:35 AM
tC9o9's Avatar
doesnt matter 225 or 215
what you want is a 40 series if you can fit it
i have 18's and i think they are perfect, all you have to do is lower the car a little and it brings new meaning to the wheels
but if you can, get your tires from tirerack.com they have a no haggle warranty, the tire pops you get another one for free, no questions asked
Old May 20, 2006 | 03:38 AM
20tCDude05's Avatar
The rim is a 18x8 and has a 35 offset:
pollup's Avatar
chances are you wont be able to squeeze 40's on a lowered tc. maybe on trd's but you will rub on bumps like crazy
Old May 20, 2006 | 03:44 AM
20tCDude05's Avatar
Hmm, we do have a lot of dips here. Guess I am gonna go with the 18x8 now, not the 19x8. What yall think of that rim anyway?
Old May 20, 2006 | 03:47 AM
pollup's Avatar
sharp looking rim.
Old May 20, 2006 | 03:49 AM
20tCDude05's Avatar
So, it's 18x8 with an offset of 35. And, I haven't been able to see many 225/35/18 tires, so could I use 225/40/18 with these rims?
Old May 20, 2006 | 03:50 AM
pollup's Avatar
nitto neogens make 225 35's
