decoding these specs
Old May 22, 2006 | 02:24 PM
singleshot's Avatar
Default decoding these specs
※1:Max. output increases approx. 15kW(20ps) and max. torque increases 20N・m(2kgf・m) in case this products, high compression piston, exclusive piston ring, sports air filter and high response muffler ver.s are installed at the same time. Orders for 2ZZ-GE enigne complete installation is receivable at TRD Direct Shop TAMA.
※2:Max. output increases approx. 11kW(15ps) and max. torque increases 7.5N・m(0.8kgf・m) in case this products,Inlet Duct(17751-ZW300),High Response Muffler Ver.S(17400-ZW300)are installed at the same time.
※3:Max. output increases approx. 7.4kW(10ps) and max. torque increases 5.9N・m(0.6kgf・m) in case this products,High Response Muffler Ver.S,TRD Sports Air Filter are installed at the same time.
※4:Max. output increases approx. 7kW(9ps) and max. torque increases 6N・m(0.6kgf・m) in case this products,High Response Muffler Ver.S,TRD Sports Air Filter are installed at the same time.
I undestand that each test was done with a slightly different set up, thus giving less and less power results, but what is the translation from kW to HP and Nm to Torque work out to?(or vise-vers)
Thanks
singleshot
Old May 22, 2006 | 02:29 PM
frogbox's Avatar
do a google search for a convertion table for metric to sae.
that will explain the numbers into something your used to, I hope
Old May 22, 2006 | 02:45 PM
singleshot's Avatar
Default expected HP increase with Header?
alrighty then..
skipping #1 due to the overall engine modifications,
#2 = 14.751 HP
#3 = 9.9 HP
#4 = 9.387 HP
I used this calculation
Kilowatts (kW) ---> Horse power (hp): kW x 1.341 = hp
So what is the HP increase "expected with the other headers (DC, Megen, strup, ect..)?
Interesting
Thanks
Singleshot
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Subaru86
Sep 10, 2015 08:33 AM
